Question about Avanti Dryers
Looking for a motor for my avanti dryer d110 - Avanti Dryers
SOURCE: I need an exhaust filter for my Avanti dryer.
I've seen two indoor vent kits that on Amazon that people use with this dryer.
http://www.amazon.com/Dundas-Jafine-TDIDVKZW-ProFlex-Indoor/dp/B000DZFTC6/ref=pd_bxgy_k_img_b
and
http://www.amazon.com/LTF-Supurr-Flex%C2%AE-Lint-Trap-Kit/dp/B00009W3HD/ref=pd_sim_hi_6
Hope that helps! :)
Posted on Nov 26, 2010
  • 3074 Answers
SOURCE: dryer on but no heat(
SAFETY FIRST UNPLUG DRYER......if its running then all thermos must be intact so it has to be two things: 1) the heating coil take the unit apart make sure the two heating points still have the cables attached and coils are intact, if they are 2) then find the thermal fuse and bypass it, take the two electrical connectors off the thermal fuse and tape them together( this is just to test, once done disconnect them as it is a safety feature and left bypass will cause a fire) if it heats then a new thermal fuse is in order>
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Posted on May 25, 2011
hunter19_46m
  • 7482 Answers
SOURCE: What material can I use to make a replacement lint
Hi renfrorichte...
I would use fibreglass window screen cut to the size needed.
Bonded with a good glue such as 3M's Weather Proof Adhesive or Contact cement.
Please take time to rate me
Posted on Sep 05, 2011
SOURCE: Need a belt and felt filter filter and dock for my
Call 800-220-5570 to order parts from the manufacturer..
Posted on Nov 16, 2011
camgraph77488
  • 371 Answers
SOURCE: Where can I find a motor for an Avanti D-24 Electric Dryer?
Hi
This company sells your parts but you will need the model number. This link tells you exactly where that number is found.
Return to the home page with the model number for a link to ordering the appropriate part. Hope this helps.
Dryer Model Number Locator - Find the Right Part for Your Dryer with PartSelect:
http://www.partselect.com/Model-Number-Locator+5+repair.htm
Posted on Jul 13, 2014
Electric cord overheated, blew fuse, need replacement
Contact Avanti Customer Service, or search for a replacement using eBay or Amazon.
May 11, 2015 | Avanti D110 Electric Portable Dryer
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
Where do i purchase a replacement fuse
If the unit is plugged into a house circuit that has a blown fuse, this unit requires "The fuse (or circuit breaker) size should be 15 amperes". See the manual at... https://duckduckgo.com/l/?kh=-1&uddg=http%3A%2F%2Fwww.avantiproducts.com%2Fmanual%2Fd110.pdf
Jun 26, 2014 | Avanti D110 Electric Portable Dryer
What material can I use to make a replacement lint filter for my Avanti D110 dryer? The original is about 9.5" round thin filter material that fits onto the screen lint filter. If I know what ...
Hi renfrorichte...
Sep 05, 2011 | Avanti D110 Electric Portable Dryer
Whirlpool Dryer Model LER5636EQ3. Runs for several minutes then stop.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 23, 2011 | Avanti D110 Electric Portable Dryer
NOT HEATING
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 11, 2011 | Avanti D110 Electric Portable Dryer
Drum will not rotate
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 05, 2010 | Avanti D110 Electric Portable Dryer
Dryers Logo
21 people viewed this question
Top Avanti Dryers Experts
Tim Whalen
richie46
Are you an Avanti Dryer Expert? Answer questions, earn points and help others
