Question about Cameras
All lights as re blinking in ex 100 after rescaling.
WELL, I HAVE DE EX 100, SO SUDDENLY THE RED LIGHT TURNED OFF, SO I CAN0T USE IT ANYMORE, I TRIED PRESSING THE CONNECT BUTTON, AND THE KEY BOARD IS ONLY WORKING AND THE MOUSE DOESN'T HAVE THE RED LIGHT...
Hello, try fitting new batteries in the mouse. The top rear half of the mouse slides back and lifts off. You will need 2x AA batteries. Use good quality ones (like Duracell) Regards, nicam49
Feb 17, 2011 | Logitech Cordless EX 100 Mouse
I have a casio exilim ex z77. My battery to my camera wont charge when I put it on the charger. The red light just blinks.
hi, once you charge your battery and the red light blink it means your NP-20 battery is damage and you need to buy new one.TIP- charge 1.5 hours only and if youre not using you camera for a long time its better to remove the battery.
good luck and thank you my friend
Jul 08, 2010 | Casio EXILIM Card EX-S770 Digital Camera
Presently charging my camera, does the red light alway blink?
Base on User's Guide of Casio Exilim EX-S600 Digital Camera, Flashing red light when charging the battery is mean "charge error"
(see the picture)
to overcome some problems that may occur, please refer to the User's Guide of Casio Exilim EX-S600 Digital Camera which can be read here:
http://support.casio.com/pdf/001/EXS600_e.pdf
good luck :)
Apr 17, 2010 | Casio Exilim EX-S600 Digital Camera
I have a 2002 Honda EX coupe with about 70k miles. The check engine light came on a few weeks ago. About a week ago, it started to blink periodically. The last time the check engine light came on (about 1...
Check engine light comes on because engine computer has detected a fault. It could be anything, from a cheap sensor to an important component out of specifications, to a service reminder. Most shops (not necessarily Honda dealers, ) have the diagnostic equipment to hook it up to your car and tell you what is wrong, before fixing anything. Usual rates for this diagnostic is below $100, including quote for repair.
Mar 31, 2010 | 2002 Honda Accord
1996 honda accord ex oil light keeps blinking
replace oil pressure sending unit...the light blinking and rough idle will stop
Aug 30, 2009 | Gateway MD2614u Notebook
Pc to projector fuzzy as hell, all diff resos.
Well the ax-100 can only display 1280x720. If you output anything different - lower or higher - the image needs to be rescaled, which inevitably makes it a bit fuzzy.
May 29, 2009 | Panasonic PT-AX100U-EC DLP Projector
Watching video in full screen on w350i
when viewing a video, click more menu, theres an option for you to click video size, there you can choose original (video size is not escaled), auto fit (rescale the video side for best possible fit, without cutting the any edges and lastly fullscreen (rescale the video size to cover the play view)
hope this helps
Nov 06, 2008 | Sony Ericsson W350i Cell Phone
Operation lamp - amber light blinking
I do not know the solution to your problem but I can tell you that when the camera is working properly that amber light means the flash is chargeing or your camera is doing something like saveing a picture so if your battery is low your flash might not charge properly or your camera might have something wrong with is memory. Sorry i couldn't be a better help.Good luck!
Sep 06, 2007 | Casio Exilim EX-S600 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
