Question about The Computers & Internet
Removing the base from amw F199B 19 inch monitor
2 Suggested Answers
SOURCE: AMW F199B 19 Inch LCD Monitor - No Red
I just changed PC and and I have a "AMW F199B" monitor that will not produce sounds now. I do not have any of the original software for the monitor. What do I do?
Thanks
Posted on Nov 09, 2008
How do I change Windows 10 resolution on a Dell laptop from 1366 x 768 to 1024 x 768? Control Panel Display won't help me do it!
right click on the desktop and click on display settings. In the new window you will see your displays numbered 1 and 2. Click on 2 and see if you can change the resolution.
Oct 04, 2015 | Dell Computers & Internet
How do you remove the base from a 19
If the scerws are removed, the base had to either rotate into positon,or slide from bottom or top to expose the screw holes before reversing the procedure.Try it,but don't break the plastic.Good Luck!
Mar 01, 2012 | Dell 1909W 19 inch Monitor
How do I remove the base neck from the monitor? I
theres a scre that is making the base stick to the monitor, take it out and slide out the base, or check the user manual for that
Feb 15, 2010 | LG W1934S-BN 19" Monitor
My F199B seems to have a bad display after
You need to download & install the Windows 7 druvers for your graphics card. Once this is done your display should be fine. Hope this helps.
Jun 26, 2009 | Advueu Technology AMW-F196B
Swivel base removal
In the back of the swivel there is a small release lever... push down (?) then with other hand hit the swivel base towards back, then lift unit up.
May 11, 2009 | Gateway VX930 19" CRT Monitor
AMW 19" LCD Monitor
go to NVDIA web site download the latest driver.
you need at least 32bit color to setup the monitor.
the 8-bit color is a default, that is why the monitor alway return to default size which is 800x600.
19" monitor should have minimum of 1280x1024 with 32 color.
don't up the color 256bit. the color will be off on the monitor.
Jan 25, 2009 | Dell Dimension 4600 PC Desktop
Thanks
Jun 14, 2008 | Advueu Technology AMW-F196B
AMW-F199B intermittent turn on
I had same problem. I found that there were 2 capacitors on the power supply which were bulging which means that they were faulty. I replaced them and unit worked ok. The values for the capacitors were 680 uf / 16V. If anyone wants any more detailed information, let me know.
Dec 14, 2007 | Advueu Technology AMW-F196B
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Remove stand
we need picture of it, if your not talking about the swivel base.
Dec 02, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
Computers & Internet Logo
48 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
