Question about DeLonghi Heating & Cooling
My delonghi pac a140e compressor won't start. What do I do?
  • 1,660 Answers
Be sure it's getting voltage, check capacitor.
Posted on May 21, 2017
  • 104 Answers
SOURCE: DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Posted on Jan 20, 2008
SOURCE: delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Posted on Sep 06, 2008
  • 10865 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Posted on Feb 14, 2009
  • 134 Answers
You need to go here
SOURCE: need any user and -or service manual for delonghi PAC -75 U
Here is the manual
Posted on Jun 29, 2010
I have a new Delonghi portable AC PAC N115EC (11,500BTU), is it normal for the compressor in this particular A/C to be cycling on/off every 2 to 3 minutes?
If the room is cool, it sounds like the unit is operating correctly. It could be short cycling because the unit is over sized for the room being conditioned. if you can, increase to size of the load by opening a door into another room. As long as the refrigerant pressures equalize from high to low side internally and the compressor doesn't start up under load, you should be fine
Sep 10, 2016 | DeLonghi Heating & Cooling
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
I just bought a used DeLonghi Pinguino PAC 02. It seems to cool ok but the exhaust hose gets very warm. Is that normal?
Yes, that is normal. It's exhausting the heat from the compressor out the window.
Thanks for choosing FixYa.
Sep 09, 2011 | DeLonghi Pinguino PAC-02 Air Conditioner
Compressor not turning on - but unit turns on and fan works - even when temp turned all the way down.
all the way down is as warm as the refrigrator can get. Sounds like start components are the problem.
Apr 17, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
Item Potential Relay Type Pro Pac
get solid state starting relay and 65Uf cap from any refrigeration parts shop or to test comp remove all wires and hot start it or email me your wireing plans and relay info
Apr 23, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Pac 35 split air conditioner not cooling
Could be:
- low on refrigeraant
- loose/burned/corroded compressor electrical connections
- bad compressor run capacitor
- tripped/bad breaker in main service panel
- faulty controller components/relays
- other...
If you don't have significant experince with similar appliances/systems a service call is in order.
May 08, 2009 | DeLonghi Heating & Cooling
Heating & Cooling Logo
66 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
