Question about RCA Televison & Video
I have an rca flatscreen and my picture went off.still have sound but no picture
alpug
  • 1961 Answers
SOURCE: my "32" rca flatscreen has
the backlight of your tv is about to be busted and must be replace but before replacing check first the ballast inverter board of the backlight lamp.you need to open the back cover of your tv to access the inverter board.in many cases a loose connection in the supply of the inverter board causes the problem that you've mention re soldering the connector of the inverter board from the power supply will cure the problem.next is the inverter board itself and the lamp you can replace them and they are available online at shop jimmy.com heres a link to the online store thans and pls rate my help
Posted on Sep 06, 2010
  • 718 Answers
SOURCE: no picture just sound new
If this is a new tv it's under warranty and you should take it back and let the store fix/replace it. Save yourself the headaches.
Posted on Feb 11, 2011
SD Tech
  • 14553 Answers
SOURCE: Have a RCA flatscreen model # L40FHD41, blue power light comes on and stays solid but I don't get any picture or sound. Screen stays completely black as if it doesn't have any power at all.
Other than checking all the connections going to it for signal it is likely a shop repair.
The nature of these sets is someone must open and inspect them and check for voltages missing.
At that point it becomes a guessing game---try the boards (purchase them) and see if a bad board.
It is always possible the front screen unit or display has failed which is fatal cost wise.
You have to weigh the cost of repair, age of set and cost of replacement in this.
The only way anyone can KNOW which board is bad is to actually remove and replace it----most shops look at it and shoot you a high estimate.
let me know if you have questions.
Posted on Mar 14, 2012
dduncan774
  • 760 Answers
SOURCE: my 42" rca flatscreen has a picture but no sound the sound started cracking then went away no i have no audio what can i do to fix this
Check to make sure that your speaker wires are not pinched. If the wires look good, then your main board is the culptrit.
Posted on May 17, 2012
daytoncomput
  • 1511 Answers
SOURCE: Samsung flatscreen tv model LN46C600F3FXZX has sound but no picture
Video section has become compromised and no longer functional. Audio being separate from the Video may work perfectly, but the Video portion sustained damage to the circuit board or the inline safety diode blew. If any parts of the Circuit Board fail, you need to replace the mainboard. The cost to generally fix a circuit board is usually more than the replacement cost for a new unit. Check all fuses or circuit limiters inside the TV and if there are no shorts, burned parts, or obvious smells on the mainboard, transient current may have trickled in and damaged sensitive electronics. Have a professional Technician do tests to locate the source of the problem.
Posted on Dec 25, 2013
I have a 2 year old 32" rca flatscreen tv when turned on picture fine after 5 minutes picture flickers stays that way
Sounds that the fault is not with any loose solder point; but the back light inverter or the main power supply regulator board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 18, 2015 | RCA Televison & Video
No picture on my RCA flatscreen
Lisa, might be backlight if it's an older LCD. The newer LED's are led lit, which lasts quite a bit longer. And give a bright picture right from the start.
Feb 01, 2014 | RCA Televison & Video
My 42" rca flatscreen has a picture but no sound the sound started cracking then went away no i have no audio what can i do to fix this
May 17, 2012 | RCA Televison & Video
Mar 14, 2012 | RCA L40FHD41 40. in HDTV
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
No picture just sound new rca flatscreen
Feb 11, 2011 | Televison & Video
RCA 26" Flat Screen suddenly no picture
The T-con board has failed but i do not think that it is sold seperately you will have to have a tech check it out if your set is just over the warranty i would contact rca they may just pay for it
Dec 14, 2009 | RCA L32HD31 32 in. LCD HDTV
I have a ps3 and a samsung flatscreen im using an hdmi cable is there anyway to run the sound through my kenwood vr 305 since it doesnt have a hdmi input
Connect cables from your flatscreen TV (or monitor?) to the receiver's audio input jacks. These could be two RCA, white and red, or Digital (one single RCA cable), or optical, if both the flatscreen and the receiver have such connector. Make sure you select the correct audio input on the receiver to amplfy the sound from the game/movie/etc.
If successful, try muting the TV's audio, to prevent the sound from creating a hollow (echo) effect.
Dec 02, 2009 | Kenwood VR-305
Please help me
I bought one too! It failed in 6mos. I sent the $ and returned the bad one for another of the same "no choice". Now they suddenly "lost" my replacement. Fix that, haha. Do you have a fax# for RCA?
Please help me.
Dec 12, 2007 | RCA L32W11 32 in. HD-Ready LCD Television
Televison & Video Logo
20 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
