Question about Sewing Machines
I have a Virtousa 163. I cannot get the machine to register the length of the buttonhole.
  • 240 Answers
SOURCE: buttonhole
When a machine does an "automatic buttonhole the feed does not move for a few stitches and maay jam if there are too many stitches made in this position. Is it an automatic buttonhole or can you choose how many stitches for your bartack? You ask about 0.5 well that is halfway between 0 and 1 on the stitchlength and this is indeed the recommended setting for buttonholes. If you are doing a manual buttonhole set your machine to this for the sides and zero for the bartacks but you only need about 6-10 stitches on the bartack. Fininsh it off securely by setting to straight stitch and stitch length zero for about 4 stitches to lock the thread in.
Posted on Jun 15, 2009
  • 1116 Answers
SOURCE: Will the Brother ES2000 sew a buttonhole without
Have you made sure the buttonhole lever is in the buttonhole tab?
This tutorial will show you how to make a zig-zag buttonhole - http://www.ehow.com/video_4433258_making-hole-using-zigzag-stitch.html
The demo is a little sloppy. I stitch into the ends and I set the stitch length to zero when making the bar tacks across the ends. It takes a little practice.
I hope this helps.
Posted on Mar 07, 2010
Testimonial: "This is how I make button holes without the attachment. I thought maybe the machine might have a setting that would follow the diagramed design witho"
  • 539 Answers
SOURCE: pfaff 2170 will not make consistently sized buttonholes
Go to the following site regarding timing your machine. Are you placing a button in the buttonhole foot so the machine "knows" how long to make the buttonhole? If you have a button stop lever to the left of your needle bar, are you pulling it down and putting it in FRONT of the button stop so it can complete the rotation?
Try www.fixsewingmachine.com
Try http://www.manualowl.com
Posted on Apr 13, 2012
SOURCE: machine only sews one side of a buttonhole
your machine may have a button hole lever that has to be pulled
down before sewing, it should be on the left hand side of the needle
if that doesn't help then the machine may need to be checked
Posted on Aug 28, 2012
SOURCE: Buttonhole feature
try changing the needle
make sure the button hole lever is pulled down, it should be on the left
hand side of the needle, if your machine has one
it's also possible that the machine needs to be checked to see if
there is something wrong with a gear or just needs some type of
adjust inside of the machine
Posted on Sep 04, 2012
How do you use the buttonhole foot on a babylock companion 1550
1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
Oct 05, 2017 | Sewing Machines
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
I need to know what the settings need to be on the Kenmore 158 machine to use the buttonholer?
You'll have to provide more information about the sewing machine. 158 indicates the manufacturer. However, there are a lot of Kenmore sewing machines from that manufacturer. The 158.1340 manual is available here: https://www.manualslib.com/manual/150291/Kenmore-1340.html .
Page 40 (41 in the linked format) begins the section on buttonholes. With the buttonhole attachment, you need to set the stitch to the second narrowest zig-zag stitch. You can use any stitch length. The description of using the buttonhole attachment starts on page 45.
Without the buttonhole attachment, you set the stitch selector to each part of the buttonhole as you reach them. The stitch length dial has to be set to an appropriate length in the block for buttonholes. The top and bottom tack bars use the same stitch selector. There are separate ones for the left and right sides of the button hole.
I hope this helps. Please add a comment with the rest of the model number on your sewing machine for specifics with your machine.
Jan 04, 2017 | Kenmore Sewing Machines
When using the button hole attachment, my fabric is not moved forward by the lower plate and thread gets caught up under that bottom plate. How do I fix this
Perhaps you have the stitch length set too short (close together) so the thread under the fabric is building up into a knot and then hangs up in the space under the needle plate. Try lengthening the stitch length and do some tests until you get it where you want the buttonhole to look.
How to Make Buttonhole on Your Sewing Machine Sew4Home
Jan 30, 2016 | Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
Pfaff 2170 will not make consistently sized buttonholes
Apr 13, 2012 | PfaFF Sewing Machines
Will the Brother ES2000 sew a buttonhole without the buttonhole attachment installed. If so, what do I do. I have set the style number plus length and width as shown on machine. It does not sew the...
I hope this helps.
Mar 07, 2010 | Brother ES2000 Computerized Sewing Machine
Buttonhole
Jun 25, 2008 | Singer 7462 Mechanical Sewing Machine
Uneven buttonhole sides
Hi, I'm a Bernina tech and can tell you you need to have a technician recalibrate your buttonhole foot to the machine. There is a function in the service program to do this. Also the machine will need a speed calibration once the buttonhole foot is calibrated. This will definatly solve the problem.
May 23, 2008 | Bernina Virtuosa 160
Buttonhole
I'm afraid that you are unable to correct this glitch on your own. Any sewing machine service center/shop will do...call around and look for the shop with the lowest 'minimum' charge. It is such a simple fix. However, although simple, the adjustment is so incrementally precise that without thorough understanding, your stich patterns could be rendered unuseable. I have no idea of the current value of your sewing machine, but if you deem the repair costs prohibitive, there is a workaround so you can complete your buttonhole. Complete your buttonhole setup as normal. I assume that you run tests first to adjust your stitch length/density of the buttonhole using the Step 1 setting. When you find the the length/density that you want, using an ink marker/crayon...whatever...being as precise as possible, mark a linear line from the edge of your length selector dial, continuing to the body of your machine. Now, select Buttonhole Setting #3, and increase the stitch length until you see the length/density that you want. Find a clear spot on your length dial and repeat the marking procedure. When you are ready to make a buttonhole, align the markings for Buttonhole Step 1 on your stitch length dial and proceed, complete your tack of step 2, stop, manually raise your needle out of the fabric using the balance (hand) wheel on the right, adjust your stitch length dial accordingly for Step 3, then on to your final tack #4. If it's only your buttonholer that is giving you trouble, take the extra 15 minutes or so, and use the workaround and mark your machine. It doesn't have to be ink, it can be pinstriping tape...whatever, and spend the money you saved on fabrics and notions instead.....good luck my friend.
Jul 27, 2007 | Singer 2732 Mechanical Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
