Standby lite is on but tv wont come on - Televison & Video
RCA TV wont start
Could be an open internal fuse or power supply failure
Apr 12, 2017 | RCA Televison & Video
How do I fix my samsung tv? It stopped working. No standby light.
If there is no standby lite I would check the power supply board first.
Jun 28, 2015 | Samsung 6300 Series UN55F6300AF 55" LED...
Ihave a 19" sharp flate pannel tv was playing and turned itself off now ihave no standby lite and tv wont turn on manually or with the remote
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 13, 2014 | Televison & Video
Polaroid 26inch lcd tvred standby light on but power wont turn on. I've unplugged the tv, changed the batteries in the remote. The tv stays with the red standby light only.
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Jan 12, 2010 | Polaroid FXM-2611C 26 in. LCD Television
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 34 No picture or sound the standby lite just keeps blinking.
Does the ligh blink a certain number of times and the stop briefly and repeat the same pattern? If so you have a problem that is beyond your ability to service it and must be serviced by a certified sony tech.
Feb 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture loss with standby lite flashing
If the standby light is flashing 4 times it indicates the TV is overheating because one of the 4 internal fans has totally failed or is not spinning fast enough. The fans start at about $35 and cost up to $65. Replacing 2 of the fans is quite easy. The other 2 require much more disassembly of the TV. I would suggest obtaining the service manual (not the owners manual) before trying to replace any of them.
Sep 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
My 36" Trinitron standby lite just keeps blinking..
Hello Nicrod,
Can you let me know how many times that light blinks on your TV? There would be a small interval between blinks and then big interval.
May 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
