Question about Sharp Office Equipment & Supplies
I have a sharp Mx-2300N it initially prints both color and B&W but now it only prints Black and white. The 3 color toner tanks and chips are intact. I would like to know why it does not print color
SOURCE: colored page in black and white
don't click on color, click on black/white and it should work
Posted on Jan 06, 2009
SOURCE: Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Posted on Oct 23, 2009
SOURCE: Hi, New to Mac and trying to find sharp driver
Thanks for posting the obvious weatlandsvc. If i were to just point people to the vendors driver page, and pass that off as the answer, I would be fired. Thanks for the obvious.
I'm working on solving the real problem!!!!!
Posted on Dec 01, 2009
xptareq2000
  • 1447 Answers
SOURCE: how to print back to back pages on sharp Mx-2300N
Back to back mean duplex print .If your copier has a duplex cassette you can use duplex print before configure it see your user guide and follow this function.
Posted on Dec 16, 2009
  • 11 Answers
SOURCE: MX-2300N Color Copier: I have a Sharp MX-2300N that has just suddenly sta...
yes open the front door remove the waste toner and you will see the 4 drum units each with a little green stick pointing out
pull this in and out a few times on each unit ...
hope this helps
Posted on Jul 13, 2010
New Black Toner installed and not recognised
1.Wrong ink chip
2.Refilled with incorrect toner powder
3.Refilled but toner chip not reset
Jul 10, 2014 | Sharp MX-2300N Color Copier
Sharp MX-2300N - can only print on computer restart
You will have to contact Sharp's service department.
Apr 30, 2012 | Sharp MX-2300N Color Copier
Call for service code f2 42
My friend I read your problem.F2 42 mean your copier toner cartridge is empty.when finished toner then reset chip.This toner cartridge have a chip.Or version problem.Now you buy a New toner cartridge then solve your problem.
Mar 31, 2012 | Sharp MX-2300N Color Copier
hope this helps
May 18, 2010 | Sharp MX-2300N Color Copier
Wondering if you can help set up a sharp
go into printer properties and see if there is an option for color...
Dec 16, 2009 | Sharp MX-2300N Color Copier
Changing toner cartridge on copier
Open up the large front door, it will swing downwards. At the top section you'll see four boxes with front handles. Each of the boxes is a slide-out container of toner.
Follow the instructions on the new toner box to prepare it for the copier.
You'll note each toner box has a color designation (on a plastic label just above where you grab). Simply grab the handle on the one you need to replace, pull it out and then slide in a new one.
Also note there are four colors: Yellow, Magenta, Cyan and Black. The LCD screen should indicate which toner bottle(s) to replace.
Aug 30, 2009 | Sharp MX-2300N Color Copier
Network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
Dec 17, 2008 | Sharp MX-2300N Color Copier
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
