What does playing upmean.? We've only used it once!
Yamaha DGX 640 - keys make odd sound
I don't think that is correctable; if it is under warranty, have it repaired or replaced. The yamaha keyboards are great when they work partly because they use sampled sounds; getting extra sounds indicates a bad chip.
May 07, 2017 | Yamaha DGX-640 Walnut 88-Key Keyboard...
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
Dec 11, 2012 | Audio Players & Recorders
I can't get movies on my GoFlex Hard Drive
you might need some certain programs to play the movies
IE adobe direct X media codec or an updated media player
hope this helps
Jun 23, 2012 | Seagate 500GB FreeAgent GoFlex Hard Drive
Playing MLB the Show on PS3. Game loads fine, franchise I've been playing loads fine. But once I try to play a game, bar starts as game loads then game cuts off and goes to main PS3 screen.
Is your CD dirty or does it have any cracks? It might just be the problem. Otherwise, it could be corrupt game data. Clean the disc, if it still doesn't work I'd try deleting the game utility data and re-downloading it. Hope this helps in some way or another.
Apr 19, 2012 | Sony Playstation 3 (PS3) Console
Youtube
If you can't play videos once you've successfully installed the YouTube for Mobile app, one of the following issues may be causing the problem:
  • Your phone may not support streaming video. Check by trying to play a video at http://m.youtube.com
  • Your streaming video access point may need to be configured outside of YouTube for Mobile. Depending on your phone and mobile data provider, this access point may need to be the same or different from YouTube's. For more help with these settings, please see the "Access Settings" article.
  • If you've successfully played videos with YouTube for Mobile before, your network connection may not be strong enough at the moment. Please try again later.
  • Your carrier might block RTSP traffic which is required to transfer the video.
    hope this helps
Feb 29, 2012 | Sony Ericsson Cell Phones
I can not get my Crosley CR248 Songwriter to Finalize when I try to transfer from cassette to cd. It keeps showing me FAIL....
I don't know this particular machine but here are some general comments.
Most CD recorders need you to press (and sometimes hold) the record button followed by the play button before tehy actually record anything (if you don't press the play button you will still hear sound via headphones etc. but no recording file will be created)
Does it record from vinyl records okay or is it just cassettes?
Are you using the correct sort of CD?
We use a Denon CD recorder and it only works with AUDIO CDs - computer data CDs or CDRWs will not work in it. Even if the Crossley will accept computer CDs it may require a particular format either +ve or -ve (labelled CDR+ or CDR-) to be compatible. Once you have tried finalising a disk and it has failed you cannot use the same disk again.
Jan 29, 2011 | Crosley CR248 Turntable
Sylvania SMPK8858 won't play movies. Keeps saying format error
I downloaded a video to flash converter from this site http://www.dvdvideosoft.com/products/dvd/Free-Video-to-Flash-Converter.htm and all the videos i run through that program work. I've tried AVI and other videos that were in flash and none worked in the player, but once I run them through the flash converter they play perfectly.
Dec 27, 2009 | Sylvania SMPK8858 MP3 Player
I have a technics amplifier SU G75
I have a technics too, and faced the same problem. The solution is very simple just ensure the +ve and -ve wires are connected correctly for each speaker to the amp. Eg. red wire to the red knob and black wire to the black on both ends. sometimes this arises because the wires are of just one color however there will be some marking on the wire to indicate which is +ve and -ve. This took care of the overload problem.
Jun 18, 2009 | Technics SA-AX530 Receiver
MY GRAND THEFT AUTO 4 WONT PLAY IT KEEPS STOPING THE GAME AND TELLING ME 2 CLEAN THE GAME WITH ACLOTH THEN PLAY IT THERE IS KIND OF BIG SCRATCH ON IT BUT ITS NOT THAT BIG SHOULD I JUST BUY ANEW ONE
you could buy a new game, but it,s worth trying this disk repair solution first. i,ve been repairing game-music cds/dvds for a couple of years, with 80% sucessful results.
1:) Find an empty jewel Case ( plastic cd holder case ) put the game-disk into the case upside down. ** Underside Facing Up**
2:) Take a soft-cloth ** Yellow Duster Type** and apply a small amount Of T-Cut Or Toothpaste. to the cloth.
3:) holding the disk with one hand, to stop it moving. use your other hand to work the cutting paste into the disk, around the scratched area. using light to medium pressure.
4:) once you,ve polished the area around the scratch, using a clean piece of soft cloth, buff to a polish.
5:) once the scratch has been removed, polish with a light solution of furniture polish, to fill in any surface inperfections.
If your in the UK, i can repair the disk for you.
mike @ Compurepair.
Jul 02, 2008 | Video Game Consoles & Games
18 people viewed this question
 Grubhead
Grubhead
