Question about HP Garden
Torro lawn mower 6.5 hp will not stay running.where is the fuel filter/?
  • HP Master
  • 2,290 Answers
Sounds like dirt in the fuel jet. If it has a fuel bowl take it off and clean it out and clean the fuel jet as well. 80 percent of the time that will make it run. Be careful you don't let the float get out of place and make sure the gaskets go back in place or you could have a gas leak.
Posted on May 20, 2017
Torro lawn mower 6.5 hp where is the fuel filter found engine will not stay running
There is a fuel strainer on the pickup pipe in the fuel tank, that is it, no external filter.
May 19, 2017 | HP Garden
Lawn mower will start and run for 5 seconds and shut down
will it stay running with your choke on? if so then clean your carb. if not then look for a blockage from tank to carb. ie fuel shut off, deteriorated fuel line. plugged filter etc
Oct 17, 2014 | Toro Power Lawn Mower
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
Torro Lawn Mower side discharge spring
There are 2 bolts with nuts that mount the spring/door assembly to the mower deck.
Jul 08, 2013 | Garden
Sears 6 hp will not start
i would look more at the needle and seat (the little valve that aloows the fuel into the carb)
Apr 24, 2012 | Sears Garden
Wont stay running
clean filters and card ir injector then run fuel system cleaner in the fuel tank
Dec 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 21 hp mower
check fuel line for colapse near frame rail common problem ? new hose from tank to fuel filter will fix it
Aug 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My lawn mower will not stay started
You need to check the fuel line for cracks/breaks. Check the fuel filter if it has one. If these two things are o.k., then you will need to clean the carb. It probably has debris in it.
Jun 07, 2009 | Toro Lawn Mower With Toro Power Tools
Won't stay running
Try cleaning out the fuel tank and replacing the fuel filter. What happens is it has enuf gas to run but not enuf to run when it demans more power. You might find earwigs int he tank clogging the fuel hole at the bottom (common problem)
good luck
May 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower will not stay running
Sounds like a lack of fuel. If it has a briggs motor replace fuel pump diaphram in carb.
Jul 19, 2008 | Electrical Supplies
Garden Logo
18 people viewed this question
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
