Question about Building Materials
Replace our Chamberlain garage door opener with a new one. Remotes work great . After clearing codes from our cars we have repeatedly tried and been unsuccessful in training them to our new opener.
  • 5 Answers
SOURCE: remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Posted on Dec 11, 2008
SOURCE: i have a pmx300IC genie
palm treo 700w off no open
Posted on Jan 19, 2009
  • 6 Answers
SOURCE: Locked out & Remote not working
There should be a green button on the back of the motor unit, press it for 2 seconds and then hold down your remote button until the light flashs. or for 3-5 seconds and then activate the remote. that might solve your problem
Posted on Jul 24, 2009
webmaster21
  • 803 Answers
SOURCE: Random operation of Chamberlain HD900D garage door opener
As for all of us as Experts at Fixya. We would greatly appreciate if you would place your question in the right category so that an Expert with knowledge of this field can provide you with help. Sorry that I could not be of more assistants. I will inform other experts in this field of your issues so that they can redirect to help you. Thank you for using Fixya.
Posted on Dec 06, 2009
  • 3197 Answers
SOURCE: Replacing screw drive socket coupler on chamberlain garage opener
There are two bolts just in front of the motor that holds the rail. Remove these and you can move the motor back enough to slide the coupler off.
Posted on Jan 08, 2010
This doesn't work for me. I've tried everything. I'm getting very frustrated, and am trying anything to prevent me from purchasing a new garage door opener. I just bought the condo, and received no garage...
It seems you have done everything right. I would return the universal remotes to Lowes and purchase the correct remote for the opener. There have been several people with universal remotes and this same problem.
Nov 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Not all remotes will work at the same time.
You either have 2 remotes that have reverted to billion code technology or you are trying to program remotes from an older unit. Either way if you need to replace the bad ones if you actually need that many remotes.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Unable to program remotes from opener
TRY UNPLUGING THE UNIT WAIT ABOUT 5 MIN. PLUG IT BACK IN CLEAR THE CODES BY HODING DOWN THE PROGRAM BUTTON FOR ABOUT 20 SECONDS.
NOW YOU ARE READY TO PROGRAM A REMOTE TO THE SYSTEM.
HOPE THIS HELPS
Aug 13, 2009 | liftmaster Chamberlain Garage Door Opener...
Can't set code for keypad and remote...one works, then when other
You have used up all of the remote spaces on the opener. You need to reset the remotes. Press and hold the learn button for 8 seconds. This clears the memory for all remotes. Then press and release the learn button and then press the button on the remote. The light will blink once on the opener. Repeat this step on the other remotes.
Feb 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
New code entry does NOT override old code on Craftsman 315 keypad
yes. Press the learn button for 8 seconds to clear the remote memory. Reprogram all remotes and keypad
Feb 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opener remotes not opening garage door.
You have to sync the remotes to the new code. For older remotes, you can open the remote and match the pin settings.
For newer remotes there's a button that you push in the back of the opener that sets in program mode (for Chamberlain). When you push the remote button, it will acknowledge the remote is programmed.
If this doesn't help, comment back on your particular model and we'll help you with the solution.
Jan 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain door lifter remote channel change
Yes. push and hld the learn code button on the operator for about 20 secs. until the light goes out. this should clear all of the codes. Than reprogram the remotes that you want.
Dec 10, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Building Materials Logo
19 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
