Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Presario wont turn on. its an f500, i turn it on and it immediately turns off, screen wont come on...im assuming i need a new battery? want advice before i purchase the battery!!
  • laurenvance Jul 25, 2009
    I removed the battery and tried to boot, the blue "on" indicator came on and then turned back off, still leaving the screen black...do I need a new battery?
    Sergeant:
  • 168 Answers
Remove the battery, plug the wall adapter in and try to boot. If it works, the battery is the problem. If not; is the green indicator on the power brick on? If not, replace the power supply brick. If all the above is ok, the problem is internal and I would be guessing without testing.
Posted on Jul 25, 2009
  • Harvey Morrow
    Harvey Morrow Jul 25, 2009
    From the info you are giving, it does NOT look like the battery is causing this problem. (If the battery is dead, it can prevent the system from powering up, which is why I asked you to remove it) An internal component, probably on the motherboard is causing your problem. The green light I asked you to look for is on the power brick. (On most, anyway) The turning on and quickly going off is indicative of a short.
My Compaq Presario F500 running Vist Home Basic will no longer boot the operating system after I completed an advise BIOS update from HPs websit. I receive an error code stating that the system is cor
Hi.
Try this >>>>
Power down your Compaq Presario F500 notebook computer. Remove the unit's internal battery from its housing compartment.
Use a screwdriver to unscrew and remove all of the screws from the bottom panel of your Compaq Presario F500. Use your hands to lift off the bottom panel, revealing the inside of the notebook computer.
Look for the CMOS/BIOS chip: It will be located in the center of your computer's motherboard, which is itself located in the center of the case.
Remove the small battery from its housing compartment on the CMOS/BIOS chip. Then, press and hold the "Power" button on the laptop's case for a few seconds. This will completely discharge all electricity from the device.
Replace the CMOS/BIOS' battery. Place the bottom panel of the notebook computer back on and screw it back into place. Place the Compaq Presario F500's battery back into its housing compartment and press the "Power" button to turn it on. Your CMOS/BIOS will now be completely reset.
Good luck and please let me know how you get on!!!!
Regards.
Jan 29, 2013 | Computers & Internet
Wont' turn on lites blink on and then go off immediately
1 motherboard is out....
2 power unit on the MB is out...
3 the power supply unit is out...
could be any....try a tech shop...
Sep 27, 2010 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario F500 F700 and G6000 Motherboard - 442875-001 : motherboard of my laptop is gone. What can I do?...
If you sure that your Motherboard is gone and wont work at all, sorry to tell you that but you need a new Motherboard and a new laptop.
May 17, 2010 | HP Compaq Presario F500 F700 and G6000...
My Compaq Presario f500 series Wont turn on anymore
I would like to help but it sounds like it's over heated and needs a repair guy to look at it
Jan 11, 2010 | Compaq Presario Notebook
Screen wont turn on
problem wit your smps chang smps andit will solve the issue
Oct 04, 2009 | HP Compaq Presario F500 F700 and G6000...
I have the same problem the battery is still good but doent start
Try to remove the PSU and the battery pack and press power, then attach the PSU and turn power on the system must turn on even there is no battery pack installed,If the power did not turn on the female connector of the PSU might be at fault
Aug 27, 2009 | HP Compaq Presario F500 F700 and G6000...
Cant turn On my Compact presario f700
Assuming you have checked the the power strip or outlet by testing it with another electrical appliance to see if it is in operation, you can test
the power supply to the unit with a tester or oscilloscope. If it still does not work then check the cable that plugs directly into the unit and replace it if necessary. You can also open the unit to check if the cable is attached properly to the motherboard.
Aug 26, 2009 | HP Compaq Presario F500 F700 and G6000...
My compaq presario power is Ok but have completely
I would assume that your hard drive is spinning? If not your system will not boot because of a faulty or missing harddrive. Last known good config only works on the operating system and would not work during POST. Can you give a little more information please?
Fehdi
Aug 19, 2009 | Computers & Internet
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
789 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
