Question about The Computers & Internet
How do I install the batteries on a iessentials wireless mouse
I put USB adapter into computer and batteries in mouse. pushed connect button I get no response out of mouse. Any ideas to make it work?
try this
I recently put batteries in a wireless key board and when I went to use it---nada
so I read the instruction on the back of the key board and it said to restart the computer
did that and problem solved
try restarting the computer with the mouse switched on and see if the computer recognizes the mouse
Nov 23, 2015 | Mizco iEssentials IE-MM-PW Mouse - Optical...
How to setup ge 99916 wireless mouse
    • 1Hold the mouse in your hand, press down on the battery compartment cover (the back of the mouse) then slide it off.
    • 2 Insert two AAA batteries into the mouse. Make sure the positive and negative terminals match up with the diagrams inside the battery compartment.
    • 3
    • Replace the battery compartment cover.
    • 4 Connect the USB receiver to a USB port on the computer. The computer will acknowledge that a new device has been installed and you will be prompted to install the software.
    • 5 Insert the software installation disc into the optical drive. Follow the instructions provided by the installation wizard to install the software.
    • 6 Press the link button on the receiver, then turn the mouse over and press the link button on the mouse. The mouse is ready for use.
Jun 07, 2014 | GE Wireless Optical Mouse
How do you change the battery in the Mouse
model no. all the wireless mouses have battery partition at downside. check it
Mar 08, 2011 | Logitech Cordless Mouse
Installing wireless mouse on Windows 7 Laptop
connect to the internet with your laptop and then plug in your mouse,windows 7 will automatically find the driver for you :)
Mar 07, 2011 | Computers & Internet
How do i connect my hp wireless mouse to the computer
The first step is to install its driver, after taht you can connect the wireless dongle into a free USB port of your computer, then put the batteries inside the mouse and turn it on, in the most of cases, the wireless dongle and mouse sinchronize automatically, if they don't, there's a small botton in both devices press it in each one to synchronize them manually.
Feb 25, 2011 | HP Wireless Optical Mouse
I installed a Microsoft Wireless Mouse 5000 using a USB connection. Is there a way to check the battery status. The program I installed that came with the Mouse does not have a tab for checking Battery...
Microsoft wireless mice typically put an icon in the system notification tray (right side of the taskbar, next to the clock) showing the mouse's current status. If you hover over this icon, the battery status should be displayed (it may just say either "OK" or "battery low").
Jun 01, 2010 | Microsoft Wireless Laser Mouse 5000
I purchased a HP laptop, Windows 7. I installed
You have to install the software that came with the wireless mouse. I have several, and some will and others won't work without the software. That is 90% what it is.
May 17, 2010 | Logitech Cordless Mouse
Quick instruction to install leeds asi/66887 wireless mouse
You need installation disc, if you have lost the CD, than go to this site Driver Update Software for XP Vista 7 8 and download their update tool. I hope I helped.
Feb 12, 2010 | Microsoft Wireless Notebook Optical Mouse...
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
Wireless mouse
STEP 1 - Battery Installation:
The first step in installing your Wireless Wheel Mouse is to install the batteries.
1 - Locate the two AAA sized 1.5 Volt batteries that came in your Wireless Wheel Mouse package.
2 - Remove the battery compartment cover located on top of your mouse by pressing the cover release button and sliding the cover backwards.
3 - Install the two batteries into the compartment paying close attention to proper polarities.
4 - Replace the battery compartment cover.
STEP 2 - Connecting the Receiver:
If you are connecting the mouse to a notebook that has an onboard pointing device or if you are using a keyboard with an onboard pointing device, you may need to
disable that device before installing and using the mouse.
Sep 14, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
