Question about HP Garden
Torro lawn mower 6.5 hp where is the fuel filter found engine will not stay running
    Top Expert:
  • HP Master
  • 77,932 Answers
There is a fuel strainer on the pickup pipe in the fuel tank, that is it, no external filter.
Posted on May 19, 2017
Torro lawn mower 6.5 hp will not stay running.where is the fuel filter/?
Sounds like dirt in the fuel jet. If it has a fuel bowl take it off and clean it out and clean the fuel jet as well. 80 percent of the time that will make it run. Be careful you don't let the float get out of place and make sure the gaskets go back in place or you could have a gas leak.
May 19, 2017 | HP Garden
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
Engine acts like it is running out of fuel
Remove gas line from carb. Fuel should run out. A pluged fuel cap vent could the problem.
Nov 11, 2013 | Yard Machines 13AC762F000 38-Inch 344cc...
Toro lawn mower troubleshooting
Clean the carb, gas tank and fuel line (s). Replace air filter with a new one, I wouldn't recommend that you run it without the filter because that allows dirt and grass debri to enter the carb, fuel line and gas tank.
Replace the plug with a new one that is recommended for your engine.
Check oil level.
Other option is lawn mower repair shop....
Hope this helps, I had the same problem.
May 11, 2013 | Garden
Sears 6 hp will not start
i would look more at the needle and seat (the little valve that aloows the fuel into the carb)
Apr 24, 2012 | Sears Garden
The engine will not stay running (Ariens 34' Zoom)
a lawn mower is not much different than a car, you still need 3 things to make it run: fuel, electricity, and a spark. you say it doesnt stay running, Before trying to make any repairs, ensure that you are using the correct fuel, also make sure the fuel lines are not leaking or crimped. if the lines seem fine, check the fuel filter and/ or fuel pump. though the mower is new, they can still have faulty componets.
Jul 24, 2009 | Ariens 34 In. Zoom Series Riding Mower
Engin will not stay running dies
No fuel filter but there is the air filter. Try removing the air filter and starting the mower. If this works replace the air filter. If not, then check the engine's carb. Engine was made by Tecumseh. There aren't many parts to a Tecumseh carb so replacing the few parts (gasket around bowl, float, needle and seat) isn't a lot of trouble.
Jun 13, 2009 | Garden
I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
Mar 27, 2009 | Garden
Mower will not stay running
Sounds like a lack of fuel. If it has a briggs motor replace fuel pump diaphram in carb.
Jul 19, 2008 | Electrical Supplies
Garden Logo
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
