Honda EU 3000is generator error codes. Output indicator light blinks 6 times on start up but generator works fine. Is this an error code?
SOURCE: Battery in a honda 3000is
The battery is behind one of the end plastic casing pieces. You have to remove the center plastic panel, then remove the bolts holding the handle in place, and then remove the small, lower metal panel. I don't remember if it is on the side where the exhaust opening is or not, I believe it is on that same side.
Posted on May 06, 2009
  • 1632 Answers
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Posted on May 22, 2009
  • 5 Answers
SOURCE: My trace inverter SW2512 will only allow pass through power.
First problem is caused by the new generator producing too high a frequency... 65 Hertz is above the inverter limit. Adjust the governor down to 60 or 61 Hertz.
Breaker tripping may be due to excessive current draw from the Honda. Check the max AC input menu on the inverter. It might have been set lower to avoid overloading the original generator but if DC power was turned off at any time while you were changing generators, the inverter would have returned to it's default settings which may exceed the Honda's capacity.
Posted on Aug 28, 2009
spekgt
  • 60 Answers
SOURCE: Our Honda EU 6500 is has a e29 code and shuts off.
Hi there
Code e-29 on a EU6500IS stands for GCU (genarator control unit) internal failure or inverter unit internal failure .The cost on a GCU is around $480.00 and the inverter is around $1100.00. On the i-monitor press and hold the button for about 3 seconds and the display will show all the error codes (5 total) . Check if there's any other error codes .
Hope this help
Posted on Aug 31, 2009
  • 4090 Answers
SOURCE: The power/standby light blinks red 6 times
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Not a DIY fix
Please rate my help++++Thanks for using FIXYA
Posted on Aug 01, 2010
Testimonial: "Thanks. That helps me in considering whether I want to get the TV fixed or buy a new one."
Engine checks lights on,blink 6 times then shut off,what seems to be the problem?
DIYer? If not, time to take by a competent service shop, or the dealer. The 6 blink probably is an error code for a major problem. When did you last service the car according to MFG instructions? Check all fluids.
May 05, 2015 | 1993 Honda Accord
No picture
can you please mention your tv model
Jun 12, 2008 | Sony FD Trinitron KV-32HV600 32" TV
How to clear the code fault on my Onan 4000 generator. What causes a fault & why???
what model is it KY KV need that and Spec. If it blinks 3 times it indicates a lower service fault. While blinking hit the stop button 3 times fast, then read the code. It will blink, pause then blink again and repeat. What is that code and I can help you. IE 4 blinks pause and 3 indicates code 43
Nov 13, 2014 | Watts Onan Portable Generator - 4000 ,...
Honda eu 6500 Error e21. First time using it and the machine is new. How to fix it? Sorry there wasn't category for generator
check oil levels as generator will not start if oil level is low. this is a built in safety device on most generators and one of the leading causes of returns to stores />
Aug 03, 2013 | Garden
Honda EU 3000is only runs on half choke
Overhaul the carb. When you have to choke it to run, there is not enough fuel getting in
May 04, 2013 | Honda EU3000iS Inverter Generator
Samsung s50hw-yb01 red lights blinks 6 times
Google the model number with "error codes" or 6 blinks or as last resort call Samsung customer service
All blink codes indicate something wrong in the set and are only general in nature--will not of course say replace this specific part.
Apr 09, 2012 | Televison & Video
D4 light on no matter what gear i'm in. 95 Honda Accord LX 4-cylinder. Already replaced solinoid, speedometer, fan,
The D4 light is coming on to tell you that there is one or more fault codes set in your transmission control module. The only way to retrieve codes on the 1995 models is to read "Flash Codes" output by the D4 light. (See instructions below)
RETRIEVING FLASH CODES USING THE D4 LIGHT
If fault codes are present, the D4 light will "blink" when the ignition is turned to the RUN position and will remain on at all times when the engine is running.
To retrieve the flash codes, turn the ignition switch off.
Install a jumper wire between the service check connector terminals.
The service check connector is a gray, 2-pin connector located on the PCM/TCM cover under the passenger side of the instrument panel. (See picture below)
CAUTION: DO NOT use the 3-pin located next to the service check connector.
Installing the jumper will place the PCM/TCM in diagnostic test mode.
Turn the ignition to the RUN position. Codes will be output by blinking the D4 light.
Note the number of blinks from the D4 light. A short blink indicates a single digit flash code. A long blink equals 10 short blinks. For instance one short blink indicates code 1. One long blink and four short blinks indicates code 14. If there is more than one fault code, they will be output one at a time from the lowest numbered code to the highest numbered code. It is recommended that you read the code or codes several times to make sure that you are reading it correctly.
Once you have retrieved the fault code(s) re-post your question and include the information for what codes you have and someone can then help you locate the cause of the problem.
May 22, 2011 | Honda Accord Cars & Trucks
BLINKING GREEN LIGHT AND WILL NOT POWER UP
You can check the Error code by doing the following.
On the Front panel hold down the Device and Menu Button for 5 seconds. The LED light will then start flashing the first set of flashing lights is for the "1"5 part of the code it will then pause for about a half second and start the ones place 1"5". The code will repeat 5 times before going off.
The Error Codes: 12 - Normal Operation; 21 - X-Ray Protect; 22 - Short Protect; 23 - Loss of Horizontal Deflection; 24 - Loss of Vertical Deflection.
The problem may also be in the power supply when you first plug the device in check how many times the Led blinks if it blinks for just over a minute the power supply is working fine. If the Led blinks repeatedly and does not stop the DM is not running.
This is a link to the service manual for you TV,
http://www.service-manual.eu/model.php?id=2710
Mar 02, 2011 | Mitsubishi WS-65909 65" Rear Projection...
Honda eu 6500 gen overload indicator light will not shut off
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Mar 29, 2009 | Xantrex Technology Trace Series Inverter /...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
