Question about Garden
Kohler lawn mower engine runs perfect for about an hour then cuts off and act like it not getting fuel let it sit for about two hour it starts back up an runs for another hour
    Master:
  • 412 Answers
Look for a fuel filter, an if you find it, replace it.
Posted on May 20, 2017
AGS 2310 Kohler 12.5 engine Runs fine for an hour then quits and won't start for another hour
Loosen Fuel cap. Sounds like Tank Vent is clogged.
When it stalls quickly loosen gas cap and listen for a suction sound. If you get that then Vent is clogged and I bet the mower will start without waiting an hour
Aug 12, 2015 | Garden
Kohler engine troubleshooting
Sounds like you got some dirt or rust in gas tank
try emptying the tank and cleaning it out. also check you bottom of you gas can too it could be souse of dirt in you tank.
Just remember to put fresh clean gas in mower gas tank after you clean it.
Aug 18, 2014 | Toro Garden
Problems kohler engine
it is a lean mixture problem, for some reason it is starving for fuel, could be many reasons for that, from stopped up vent on fuel cap to dirty injectors.
Jun 18, 2013 | Garden
Simplicity riding mower with 16HP Kohler engine stalls after about 15 minutes. Acts like it isn't getting any fuel, but it will run again later.
I have seen this problem a few times and this may not be the solution however, check the fuel filter. It may have melted and partially closed off the fuel supply. The routing of the fuel hose will cause the inlet end to bend slightly if it gets too hot under the hood.
Aug 24, 2012 | Simplicity 44in Broadmoor Lawn Tractor...
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Mower will start up cold, i will mow for a half hour then it sputters and dies. After it sits for a while and cools it will start again, but not as easily as the first time. It will again mow for a while...
The valves DO NEED adjusting every 250 to 300 hours of service. That is why it dies out beleive me. It is not that hard to do if you have a service manual to help you along to perform this task
Jul 09, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have a craftsman gt 6000 with kohler 18 hp magnum today it started fine and ran goodd for over an hour i put gas in it and ti would not stay runing it stated surging and popping and cuts off
Your carb is full of trash. you also probaly need to clean out the bottom of your fuel tank, blow out your lines and replace the fuel filter. I have 2 mowers with kohler engines and clean out the fuel tanks fuel lines and carbs 1 time a year. There is also a fuel shut solenoid on the carb this is normally problem if the engine does not run. but I am certain your problem is a simple fix, all you have to do is clean everything out in the fuel system.
Sep 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower
First ncheck for a dirty fuel filter, if its dirty enough it will starve the engine for fuel after a few minutes, then slowly let the fuel system refill as it sits.
Aug 27, 2009 | Garden
Runs good for about an hour, then needs 15-30 minute rest period
When it's about to quit, quickly undo the gas cap. If it roars back to life, you have a vacuum problem, where the vents aren't letting air into the gas tank to replace the used fuel, so after a while, gravity isn't sufficient enough to pull gas from the tank until is sits and equalizes for a while.
Jun 30, 2009 | Husqvarna Zero Turn Mower Z5426
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
