Question about Samsung Dishwashers
Samsung dishwasher will not go on wash cycle. Can I reset the Program?
3 Suggested Answers
markevans
  • 148 Answers
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
Posted on Dec 28, 2007
  • 7 Answers
SOURCE: Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Posted on Jul 29, 2009
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Noise on wash cycle
Support - Dishwashers DW80F600UTS/AA ' Samsung ...
www.samsung.com > Home > Support > Dishwashers
Samsung ElectronicsVisit Samsung today for DW80F600UTS Top Control Dishwasher with Stainless Steel Tub (Stainless Steel). You'll find product ... Yes; Sound Level (dBa) 48 dBa; NSF Certification Yes; Total Number of Cycles 4; Total Number of Wash Options 2 ...Multiple wash arms ensure even water distribution during a cycle. 3 (Upper ...
Oct 01, 2015 | Samsung Dishwashers
How can i set program time when power failure during dishwasher is running ?
There should be a "cancel and drain" or similar to drain the machine and so you can restart your choice of wash cycle when power comes back on again. I don't believe it's possible to have the machine resume from where it was in the wash program if the power fails.
Sep 26, 2015 | Samsung Dishwashers
Samsung DMT300RFW Builtin Dishwasher will not run past wash cycle. I start it and it fills and the wash cycle starts but won't cycle past the wash cycle. No error codes.
What do you mean, it won't "run past the wash cycle"? Do you mean it stays in the wash cycle forever? Or do you mean it quits in the wash cycle and doesn't rinse or dry?
Oct 18, 2014 | Samsung DMT300RFW Builtin Dishwasher
MY BRAND NEW SAMSUNG DISHWASHER HAS POWER BUT WONT START THE WASH THE WASH CYCLE THE TWO CYCLE LIGHTS JUST KEEP BLINKING
What 2 cycle lights? Samsung dishwashers indicate problems and errors by making different lights light up and/or flash. We would need to know the model number too.
Oct 07, 2014 | Samsung DMR78AHS 6 Cycle Stainless...
Does this dishwasher have an auto reset or shut off process? Needed to stop dishwasher from washing cycle. Couldn't find "off" selection so left door ajar. When left, the dishwasher was beeping...will this...
If there is no obvious "Cancel" function on the control panel, holding the button on the program selected for longer than 5 seconds usually cancels the last program selected on dishwashers.
Dec 11, 2009 | Washing Machines
My Gaggenau GI904-760 is stuck in the wash cycle
sounds like water in the base ,have to grt it out
Sep 15, 2009 | Gaggenau GI936-760 Dishwasher
Reset model smu7052uc
there is none- if the program is mucked up-- pull the plug for 5 minutes
Jul 16, 2009 | Bosch 24 in. SMU70 Built-in Dishwasher
Unable to reset wash program
Press and hold the start/stop button for a few seconds.
Nov 25, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
Error code 2H
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
55 people viewed this question
Top Samsung Dishwashers Experts
Rod
Rod
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
