Question about Garden
Kohler lawn mower motor--rns perfect for about an hour then cuts off
  • 513 Answers
SOURCE: The battery is not charging from the lawn mower,
they have a stater that usually sits under flywheel for the charging system
Posted on Jun 28, 2010
  • 3740 Answers
SOURCE: We were wondering the torque on the head bolts on
Hi and welcome to FixYa. I am Kelly. These torques are from the Kohler Service manual for the
There are 5 bolts.... as you look at the bolts there should be 3 on the left side
Bolt 1 is the center (offset bolt)
Bolt 2 is upper right
Bolt 3 bottom left
Bolt 4 upper left
Bolt 5 lower right.
Torque them in the sequence above... to 15 Ft lbs. or 180 inch lbs
reset your torque wrench and then torque them to 30 Ft lbs or 360 inch lbs.
Rocker arms center nuts (called mounting screws) are first torqued to 55 inch lbs then to 100 inch lbs.
Then to set the valve lash you back off the set screw lock nut torque and set the valve lash to .003 - .005 final set screw lock nut torque is 65 inch lbs. Engine must be at TDC i.e piston all the way to the top to make the correct adjustments.
Thanks for using FixYa.
Posted on Jul 17, 2010
  • 8197 Answers
SOURCE: Where can I order an owners manual for the
You can get the manual on the links below.
Posted on Sep 02, 2011
  • 586 Answers
SOURCE: what would cause my toro zero turn lawn mower to quit pulling?
Put as you have stated it, the most simple answer is that it has a broken drive belt - unless it is shaft driven. If it is, then you need to take it in to a good mechanic. Also, if it is indeed belt-driven, and the belt broke, it's ability to pull would have been immediately obvious and you would have seen remnants of the drive belt either on the lawn or, when you checked it, it would still be, although broken, stuck up in the belt housing. . .
Posted on Apr 14, 2017
  • 412 Answers
SOURCE: kohler lawn mower engine runs perfect for about an hour then cuts off and act like it not getting fuel let it sit for about two hour it starts back up an runs for another hour
Look for a fuel filter, an if you find it, replace it.
Posted on May 20, 2017
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ... > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Safety switch on brake handlechecks ok but motor cuts off when released
check clutch safty switch or seat safty got to be one of those switches
Oct 03, 2014 | Kohler Engines Kohler Command OHV...
I have a Murray 17.5 HP Twin 46" automatic drive riding mower that only moves very slowly. What are possible causes?
If the transmission is hydrostatic and has some hours on it, the transaxle may be going bad. If this has been getting worse as you use it. If the problem happened suddenly, could be a belt loose or stretched.
Jun 26, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Jun 14, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
