Question about In Microwave Ovens
How long to make baked potatoes in pressure oven what settings do I use
MicrowaveSvc
  • 9047 Answers
SOURCE: I used the sharp to bake potatoes and after two
Assuming that the internal cooling fan was working properly, it may be as simple as a failed magnetron thermal cutout.
I don't have an exploded view on this one, and the supplier's part list is not detailed properly, so you would have to remove the magnetron thermal cutout and look for the numbers on it, either 145 or 150.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Then here would be the part numbers:
RTHM-A080WRE0 Thermal Cut Out 145 Degree c
RTHM-A085WRE0 Thermal Cut-out 150'C
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
You should also check the 20A ceramic fuse. Fuses can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
If you need more help, please replay back. Otherwise...
Posted on Jun 24, 2009
caroldon
  • 17129 Answers
SOURCE: SET TIMER FOR 20 MINUTES FOR BAKED POTATOE.. CAME
That was a very long duration to have set for potatoes. It would have made the magnetron burnt by exeeding the limit and findinf there was no conductive medium by moisture , it has ended up burning the magnetron.
First of all clean up the inside and clean up the point of the magnetron beam.Now confirm on the inside to be totally dry.
Disconnect power and check inside for break of fuse to the magnetron.If the microwave does not heat on testing with a cup of water , then it is possible that the magnetron is cooked.
Confirm the cost for the unit to decide on replacement.
Hope this helps.
Posted on Aug 21, 2010
  • 713 Answers
SOURCE: My parents have purchased a
yea you can bake sweet potato in it on the pan 30 min. on each side.
Posted on Feb 22, 2011
heatman101
  • 43501 Answers
SOURCE: I baked a potato for 10 minutes, burnt it, and
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Posted on Jul 03, 2011
dollieread
SOURCE: after using the baked potato
try unplugging it for a few minutes, it should reset
Posted on Jul 19, 2012
Microwave starts by itself
Likely a microprocessor/control panel issue. Microwave ovens that sit over ranges often have electronic failures due to heat, humidity, and grease, from the range below, which come into contact with their main circuit boards.
Apr 16, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
SET TIMER FOR 20 MINUTES FOR BAKED POTATOE.. CAME BACK AND FOUND POTATOES CHARCOALED. SMOKE AND SINGED INSIDE. MICROWAVE WILL NOT COME ON. CHECKED CIRCUIT BREAKER. POWER TO UNIT.
Hope this helps.
Aug 21, 2010 | LG LMV1630 Convection/Microwave Oven
Baked potatoes went up in flames now microwave has no power no lights. power outlet has 110v ac
Were the potatoes wrapped in foil? If so, the megatron tube was burned out. Replace unit.
Nov 06, 2009 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
Ron Dufek
Ron Dufek
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
