Question about Cell Phones
The small plastic piece covering the charging port has broken at the edges covering the port... the charger will not stay plugged in. Can anything be done to replace or fix this part...seems flimsy
    Master:
  • Cell Phones Master
  • 515 Answers
You have to fix it with feviquit
Posted on May 20, 2017
3 Suggested Answers
  • 4102 Answers
SOURCE: The small plastic piece that covers my charging
hi, the only way you qwill get a replacement is if you go to a small phone shop that sells and repairs phones and then they might have some spares off phones they have taken apart for spares, but as for buying a new piece you just would never find one to be able to buy a new one.
So your best bet would be try a small phone shop and see if they have got any spare parts for your phone as they sometimes keep all the good parts off the phones that they have had come in that are beyond repair, but failing that it would be near impossible to find somewhere that could get you the parts cheap enough to make it financially worth it.
Let me know how you get on or if you need further assistance ok
Posted on Nov 05, 2009
SOURCE: CHARGING PORT FAULTY..WHAT TO DO
took charger connector apart and soldered pins a bit thicker to make a tighter connection and now works fine !
Posted on Feb 08, 2010
I am looking for a micro usb port for fcf-4 94v-0
you may have broken the plastic clip that holds it steady. you can either take it apart and try to repair it. i had a toshiba that i had to remove the cover and fabricate a holder to keep it from pushing in when i plug the charger to it.
Mar 27, 2014 | Computers & Internet
I can no longer plug the charger in my TracFone to recharge
First off look into the charging port on your TracFone. If there is anything lodged in it then try to remove it with a paper clip or by blowing. Next look to see if the pin in the charging port (could also be a small rectangle, like the top of a flat screwdriver) is bent or broken. If so the phone is broken. Finally look at your charger, if it is bent or broken, try to find another charger to test the phone with
Mar 06, 2013 | tracfone.com
Where is phone's charger port?
It is the same spot you plug your charger into, the hole on the phone. generaly on the side or the bottom.
Dec 04, 2009 | Cell Phones
Won't Charge
You need to change the battery. It is not a fun thing to do. Do a word search for Navman PIn 570 Replacement battery either on Google or Ebay. You have to disassemble the unit to get to the battery that is taped to the unit's motherboard. There are hidden screws on the back of the unit, then you have to gently pry the 2 halves off. Big Heads up here: the round dial on the left side...be sure to tape that in place when you first disassemble the unit, otherwise it falls out into 2 or three pieces...that dial is a pain to get back together if you do not tape it.
I recently replaced the battery on my unit. There are two additional screws on the back of the unit, near the bottom in addition 2 screws under the flip up antenna. They are covered by small black plastic discs which need to be pried off first. After removing the rear cover with a knife edge (or similar) there are several other screws which attach the circuit board to the front of the unit which need to be removed. Note that the one near the edge should only be loosened, and the board slid out sideways. Once this has been done you should be able to access the battery which needs to be pried off the board, as it is attached with an adhesive patch.
(If the battery is totally dead it takes about a day before the charge led starts flashing.)
May 20, 2009 | Navman PiN 570 GPS Receiver
Something is either work my my charger or the phone for the lg vu. a few days ago, the charger worked fine but for some reason its ot working but the red dot on the charger is on; when i plug it to my...
It is loose now the charging port may have gotten broken. It happens with the LG VU's.
If this is the case, you have 3 options.
1. repair -warranty preferably
2. new phone
3 or external battery charger. cheapest option
Check out the following link for more information
How to Charge LG Vu with Broken Charge Port
Mar 07, 2009 | LG Vu CU920 Cellular Phone
Envy charge port keeps breaking
Try this one open your verizon phone.remove the shield can.. the one that covers all the components. See the usb port?solder both side of the usb connector to the ground.. that will make the connector stable and prevents from port from breaking
Dec 22, 2008 | LG enV VX9900 Cellular Phone
AOC lm929 monitor
AOC LM929 or Envision EN-7100 removal instructions:
DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
with a small flat head screwdriver, insert into the edge and pop open the small plastic
pieces that surround where the stand connects to the monitor. put plastic pieces aside.
lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
remove 4 screws in the center that hold on the stand. put stand and screws aside.
lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
side edge of the grey plastic and turn screw driver so the plastic surrounding the
screen edge pops up exposing an area surrounding the screen. put plastic rectangle
piece aside.
slide out plastic buttons piece from the side and put aside.
with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
the screen assembly to the back housing. now lift screen assembly out of the plastic
housing. put back plastic housing and screws aside AND lay the monitor screen with the
FRONT side down on a flat soft surface.
with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
cover. slide the cover down and remove. put the cover and screws aside.
USE CAUTION!!! Some components may still contain a charge.
check fuse... whatever...
Aug 29, 2008 | Computers & Internet
MFC240C
bye, bye mfc...
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000087/faq002487_000.html?reg=us&c=us&lang=en&prod=mfc240c_all
May 22, 2008 | Brother MFC 240C All-In-One InkJet Printer
Lg prob
it is better way if you have warranty then make use of it ...
if not if you are good at opening then open it and just have a look near port ... if you have the broken piece join it by soldering...
if you dont have that broken piece then just take two small wires an d carefully identify the positive and negative in the circuit board & solder it near the port which is used for charging and then cut the pin of the charger and connect the positive & negative correctly to those wires whenever you want to charge ....
else visit the technician he will replace if the spare part of it is available ..
this doesnot charge too much it is affordable so i suggest you to visit the technician....
Apr 15, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Charger port
Go to www.factorydirectcellular.com. They sell a battery charger that doesn't require the battery to be attached to the phone. This will work for the LG EnV phone. $17.00 + $3.95 shipping. Case closed.
Apr 01, 2008 | LG enV VX9900 Cellular Phone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
