Question about The Computers & Internet
Memory on 1997 lumina radio not working,it was but stopped after I put in a new radio and it sparked when I slid into the dash
The new one quit working so i put old one in it works but not the memory
  • 141 Answers
SOURCE: Brake Light Problem -1997 Chevy Lumina
The ground wire in the trunk area, coming from the brake light harness, might have come off or really loose. Hope this will get your lights working again. Best wishes.
Posted on Jan 20, 2009
joecoolvette
  • 5660 Answers
SOURCE: 1981 corvette new radio
See if you get power from the gray wire. Use a 12 volt bulb, or a multimeter.
Posted on Apr 28, 2009
mcgyver468
  • 710 Answers
SOURCE: no dash or radio lights
MAKE SURE THAT THE DIMMER SWITCH IS NOT TURNED ALL THE WAY DOWN. IF IT CHECKS OUT, THEN CHECK THE FUSE FOR THE INSTRUMENT PANEL LIGHTS. IT SHOULD BE UNDER THE DASHBOARD ON THE DRIVERS' SIDE OR TO THE LEFT OF THE AIR DUCT NEAR THE DOOR HINGE. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
Posted on May 18, 2009
SOURCE: radio fuse on 1997 Geo Metro
the appropriate fuse is blue (15A) and is third or fourth from the side of the car (the narrow end). Look at the fuse box cover.
Posted on May 31, 2009
  • 171 Answers
SOURCE: i have a 1997 chevy lumina and i'm putting in a
1997 Chevrolet Lumina Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Yellow
Radio Ground Wire: Black/White
Radio Illumination Wire: Gray/Black
Radio Dimmer Wire: Brown/White
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Posted on Jan 09, 2010
Put in new battery,and radio quiet warking
You have inadvertently disconnected the power to the radio or blown the fuse to it.
Jan 31, 2013 | 1997 Chevrolet Lumina
I have a 1997 lumina with 3.1L. the problem started with loss of power under load and p0300 code. check coils and vacuum leaks both OK.change spark plugs and wires.[same problem] check compression OK.
Since you changed the sensor we will assume it is working. When you disconnect it you put the computer in limp mode which stops it from using sensor values. If code 300 is the only code we will assume the coolant temp sensor and others are ok.
I would check fuel pressure with a gauge next.
Aug 21, 2012 | 1997 Chevrolet Lumina
How do i reset the radio for my XM Sirius? How do i remove KDC-BT742U from dash to reset using tools provided? book is just not clear enough on this.
There is no need to pull the radio from the dash to reset. There is a reset button above the aux in put behind the usb door. You will need a paper clip or a tip of a ball point pen. Once reset you will need to reprogram all of your setting (FM stations, clock) as this will wipe out the memory. To remove the radio from the dash will depend on what kind of car its in. Some (Toyota, Niss.) use the factory brackets to mount in the dash. IF this is the case the dash will need to be disassembled. For the kit installs you will need to remove the trim ring around the outside of the face of the radio. Then the keys will be inserted on each side of the radio releasing the clips then the radio can be slid out.
May 15, 2011 | Kenwood KDC-BT742U
I have a 1997 chevy lumina and i'm putting in a new radio but the wires are not hooked up to the old one and i need to find out how to hook up the new one correctly. where can i get the wiring diagram for...
Jan 09, 2010 | Car Audio & Video
My 1994 chevorlet lumina apv-3.1 motor: when you
when you say car lost power bought a new battery.sound like alternator not charging battery.with car running your voltage at battery should be 13.5 volts or 14.5 volts it not alternators need replacing.have garage replace alternator if faulty because 1993 to 1994 cars if you disconnect battery car would lose memory causing car not to idle.the car will stall out at a stop light or stop sign whole lot.it would relearn itself but the stalling out dangerous around a lot of traffic.
Nov 26, 2009 | 1994 Chevrolet Lumina APV
Both turn signals stopped working; Need to replace flasher
well its usually located under the dash and clamped onto the steering column and is silver and round in shape and color, you just unplug it and plug a new one in. its very simple. enjoy
May 26, 2009 | 1997 Chevrolet Lumina
97 Chevy Lumina Completly Stops while driving
When it stops, does it have spark? (crank sensor)
Apr 10, 2009 | 1997 Chevrolet Lumina
1997 Toyota 4 whl. Drive/6 cylinder..clock & radio light problem?
The clock unit is just defective and needs replaced. It is pretty common on these 3rd gen (96-02 Runners) -they are not cheap so many folks have just given up on them. T4R.org is a good place to look for one or a local junk yard if you need to replace it. While you have the dash apart for the clock then ...
Your radio issue is likely in the unit itself-and replacing the radio head unit with a more modern unit would likely be around the same cost as any fix of the old unit. Since many car stereo outlets install for free your only limitation is how much you choose to spend or the features needed. I seriously doubt Toyota can fix your light in the old stereo for any less than a new radio itself....but of course call the dealership and ask to be sure before you go spending big money....
Ron In Denver
Jan 31, 2009 | 1997 Toyota 4Runner
1997 Pontiac Sunfire Radio Won't come on
loose ground for radio ..dash/ instrument cluster area good luck
Nov 19, 2008 | 1997 Pontiac Sunfire
Computers & Internet Logo
26 people viewed this question
Top The Computers & Internet Experts
Ap12
Ap12
MonsterByte
Level 1 Expert
Kelley Hopper
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
