Question about Photography
Lock locked on suitcase won't open tried known comgination
SOURCE: I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Posted on Oct 11, 2009
SOURCE: I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Posted on Oct 17, 2009
SOURCE: Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Posted on Dec 04, 2009
SOURCE: presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Posted on Mar 01, 2010
matt2414
  • 247 Answers
SOURCE: How do I reset the combination lock on my
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
Posted on Mar 19, 2010
How to reset a combination lock for samsonite luggage?
if the suitcase is open, look for a little red tab on the inside. Move it to the other side of the little window, then change the combination. If the suitcase is locked, you will have to try from the outside to find the correct combination
Mar 11, 2015 | Samsonite Photography
How do I make my lock lock again
Does the red indicator show ?
Is it a padlock or suitcase lock ?
It sounds like the combo has been changed.
Feb 19, 2014 | Locks & Locksmithing
How do you open the Ruby Red Melissa and Doug's trunki suitcase?
Trunki has secure locks that keep your child's favorite items safe inside for the ride. Simply slide the lock down to close and use the keys located on the ends of the shoulder strap to lock it in place. Unlock and lift the locks to open the suitcase again.
Aug 14, 2013 | Melissa And Doug Trunki In Ruby Red
How to change lock code in TSA007 lock?
Nov 30, 2012 | Samsonite Tripod
My combination on my california pak luggage does not work. How can I open/reset the combination?
If the lock is unlocked - try this: Unzip the inside liner, find the lock backing plate. Undo the 2 screws and remove the lock from the suitcase. Find a good strong light, and maybe a magnifying glass. Look at the 3 holes in the back and rotate the dials until the 3 slots are lined up. Open and close the lock, noting the combination. Re-assemble the lock on the suitcase. Hold the lock open, dial in your own combination. Make sure it works before locking it up. Cheers
Aug 27, 2011 | Locks & Locksmithing
Please tell me how to set teh lock code for my samsonite silhouette 11 HS....no instructions were included! help!!
Sure... here're the instructions - open the suitcase, then open the zipper in the modesty pouch (it is mounted on the backside of the suitcase, along its entire length), and then from in there, take out the plastic packet. In the plastic packet are labels, warranty information, AND voila - the instructions to set the combination lock... :-)
I would tell you here too:
1. Open the suitcase
2. Look at the inside back of the lock - you would see a red color tab, and two markings - A
Aug 30, 2010 | Samsonite Silhouette 11 SoftSide 22"...
Oct 16, 2009 | Samsonite Tripod
I have a VIP suitcase with three digit combination lock. Thouh I have not changed the code, it is not opening. It seems to have stuck. I have tried to open it even with a few earlier combinations or my...
I just opened mine. I also knew the the password and the suitcase wasn't unlocking. If you are all sure that u know the password. Then put some oil in the lock. wait for 1 hour... This will help. If it doesn't work then.. Put the lock code and push the clips manually with a pait or scissors or a small blunt knife.. Don't worry the lock is just stuck. After all it's a vip and not samsonite
Mar 21, 2009 | Baby Gear
Presto combination lock on a suitcase will not open
Jan 14, 2009 | Extensis Suitcase X1
Photography Logo
224 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
