The water in the bottom draw do not drain all the water after a wash but the strainer is not blocked
SOURCE: water not draining from drawer
Could be the little non return valve mounted underneath the top drawer. Lie down on the floor under the top drawer, remove the main plastic pannel covering the bottom to expose the black drainage hose (you may need to cut away a cable tie). Remove the drainage hose from bottom of the drawer - at the start of the drainage hose there will be a small rubber type flap - if it looks broken or worn out, it will need replacing - call F & P for a replacement, approx $5 + postage for a pair (one for the top drawer and one for the bottom)
Hope this helps
Posted on Feb 13, 2008
eagle338
  • 4889 Answers
SOURCE: fisher paykel DD609 diswasher -
It is usually due to a small piece of broken glass or plastic blocking the little propellor that pumps the water out, (think of the little paddle in Nemo's tank)
You need to remove the bottom of the machine, undo one screw and twist the pump free, fairly easy, but make sure you turn the power off first. The outlet hose and pump will then be accessible, have a look in and turn the paddle with a screwdriver, bet you will find something blocking it. Shake it out and reassemble
Posted on Mar 22, 2008
  • 25 Answers
SOURCE: beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Posted on Jul 16, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune won't drain
your pump is clogged with matt mud...
remove the back panel
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Posted on Oct 04, 2009
  • 13 Answers
SOURCE: the dishwasher isn't draining properly. Not a
Sounds like you have a bad drain solonoid very common problem and easy fix.
Posted on Oct 23, 2009
Clogged drain pipe on A8200 may tag washer
always come out the back of machine someplace
Sep 30, 2017 | Washing Machines
Water not draining away, what can I do
Take out the bottom rack and put it aside. In the bottom of the dishwasher, there is a plastic strainer that screws in. Remove the screws and set them aside with the strainer. Feel around for anything in the hole which could be blocking the drain. Often labels, soapscum, food particles, etc., get in there. If there is standing water, mop it out so you can see in there. After you've cleaned out the drain, replace the strainer with its screws and the bottom rack. Try the dishwasher out by letting in a little water (an inch) at the start of the cycle, then turn it to the end of the rinse cycle to see if the water drains out. Hopefully that will fix your problem without having to call in an expert.
Feb 25, 2015 | Dishwashers
How do I get to the pump to clean it on my Kenmore he5 washer
Remove the bottom panel in the front or toe kick area. It's 2 or 3 small screws and lifts up. You may have to tilt the machine back to remove it. The pump and strainer are accessible there. The strainer cap screws off, put a catch tray under it because up to quart of water can drain there. Clean the strainer of debris before replacing pump.
Feb 14, 2015 | Kenmore HE5t Steam 4.4 cu. ft. Front-Load...
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
Hi, Ive just come home and found my Hotpoint WML720 WASHING MACHINE still full of water with all the lights flashing. It would not pump out and eventually I managed to empty it by continually using the...
That sounds like the drain pump is clogged with large ball of lint or strainer is clogged. The drain pump is in the lowest part of washer machine and more than likely behind that bottom panel. I'm in US and don't have access to parts breakdown so I can't say 100%. But, if you can locate pump, the screen would be attached or you might have to remove hoses to get debris out. Good Luck
Sep 28, 2017 | Washing Machines
We saw water leaking out of the soap compartment at the top of the washer, close to the end of a washing cycle. What could be the problem?
access the service panel usually at the front on the bottom or back, and unscrew the round cap that contains the filter/strainer and make sure it is not blocked. Sounds lie it is restricted causing slow drain.Please let me know if this helps
Jan 20, 2011 | Kenmore Front Load Washer
Large amounts of water leaks out of the washing powder tray when it starts to drain.
water leaks from the draw when spinning is normaly due to the sump hose(filter) blocked,the filter is fitted into the bottom sump hose.
Aug 23, 2009 | Hotpoint Washing Machines
THE CODE LD IS SHOWING UP AND WASHER IS NOT OPERATING
Press stop, cancel twice to reset. The Ld error is when it takes longer than 5 minutes for the washer to drain and reset the sensor. You probably have a partially plugged strainer or drain line. To check the strainer, remove the kick panel at the front bottom of the machine. The strainer is ibetween the drum and the pump, being connected to the drum with a rubber hose. Open the strainer (caution, water!), and clean. If you did not find much in the strainer, clean the drain hose. Dump the contents of the drain hose into a bucket. If possible, run an empty losd with dth drain line pointed outside.
This should fix your issue!
Best regards, --W/D-- feel free to rate this solution...thanx!
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Fisher & Paykel drawer dishwasher will not drain properly
We had this problem. wqe had a small bone blocking off the drain tube a bit. Take all the parts on the inside of the draw out ie mesh rack, remove the strainer, steel plate and remove the spinner. Now get a small pipecleaner or brush and poke it up where the strainer inlet is. You will probably see it pock through the centre where the spinner is. Give it a go.
Sep 25, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
