Question about RCA Televison & Video
Rca recorder/vcr combo trays won't open and record lights stay on
There is a vhs tape in the drawer and also DVD disc is in its drawer. Plug the rig in, and both of the record lights come on. I can't get the trays open to remove the tape/disc. I've tried all suggestions ... results not good. Please help.
  • 3130 Answers
It sounds like you got the old electrical surge blowout going on there bud. It could be as simple as a bad regulator transistor or IC. the onlt real way to tell is to troubleshoot this unit by getting a service manual and a meter and checking your standby and switched power supply. Now since this is a recorder maybe it is wort a look at by your local repair depot or is there any warrantee left on it at as my book says it has a 1 year warrantee but just dont volenter any info how it went out if ya get my drift. Good Luck
Posted on May 22, 2006
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
  • 9 Answers
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Posted on Jan 03, 2009
  • 21 Answers
SOURCE: Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Posted on Jan 27, 2009
SOURCE: VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Posted on Jun 05, 2009
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
How do I record a vhs onto a dvd on the combo?
I have researched the manual for this particular device and you will not be able to convert/record VHS tapes to DVD discs. You can however record content from a DVD to VHS tape as this model only has a readable disc player not a DVD burner. Sorry, but you may want to research DVD recorders that also have VHS playback.
May 02, 2011 | Insignia IS-DVD040924 DVD Player/VCR
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
I have a rca drc 8295 and have old family movies on vhs and want to record to dvd. what dvd do i need dvd r?
Use the DVD+R Disc better for transfering recording.Read ur DVD Recoder/VCR combo owner manual,before u do this,for the correctly setting to do transfering recording.
Jun 23, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
RCA 8295n dvd-vcr combo starts recording from VHS tape to disk and then stops.
Is the VHS tape a store bought movie or show?
MacroVision and other copy protection systems are put into store bought tapes and discs of movies and shows, and are read by your recording equipment. Once it reads this, it stops recording.
Does the screen turn red before it stops? This is one of the indications that MacroVision is stopping you.
Aug 28, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Recording from vhs to dvd
As long as you've got the DVD recorder set to the correct "channel" I can't see why it won't work. Why don't you just try it out on a DVD-RW first ? Use RCA cables from the VCR "OUT",  to the DVD recorders "IN" sockets and you'll be okay. If for some unknown reason it doesn't copy you haven't used a good disc. Probably won't copy anything with Macrovision(or other copy protection) though.
Sep 05, 2008 | Sony RDR-VX515 DVD Recorder/VCR
Record from VHS to DVD
i should imagine so if they are not copy protected films i.e shop ones .if they are tv films on tapes etc then it would be possible to do so.
via insert the vhs tape and insert the blank dvd in to its tray
play the vhs tape and press rec to record on to dvd .
although the manual might give a better guide to doing this .
Online User Manual and Guide for Samsung DVD-V4600 DVD Player / VCR Combo by FixYa, Page #1
Mar 26, 2008 | Samsung DVD-V4600 DVD Player/VCR
Jan 20, 2008 | Televison & Video
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
