My TV screen is not centered how do I fix the issue
How can I fix a faded on the upper right corner for my sunbrite tv?
Hello... you have a backlight issue. If you are technically inclined, you might be able to fix it if you can find LED strips for your model TV. However, the screen is VERY fragile and you could make the TV unwatchable. I would have a service center diagnose it and advise you whether it is repairable. I hope this helps.
Nov 11, 2017 | Televison & Video
What is the cause and is there a fix for the two vertical lines in the center of my LG monitor.
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 11, 2014 | LG M4225CCBA 42 LCD TV
I have a 1 in all four corners of my T.V. and a 189-0.19 thing in the center of the screen and can't use my remote to fix the issue
I have the same thing. All was fine until I hit the direct tv remotes mute button then immediately the volume went UP and the remote no longer worked for the TV. Amazing.
Mar 13, 2011 | Symphonic ST419E TV
Toshiba 52RV535U LCD TV The right 1/3 of the screen is multi-colored vertical lines. Can this be fixed? How and what is the likely cost? Many thanks George
Many people are having this issue. Search for 46RV530U. There is someone trying to file a class action suit for this exact issue.
Jan 12, 2011 | Toshiba 52RV535U LCD TV
White dots all over the screen
White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue.
Please contact nearest Samsung service center or local tv repair shop for repair estimate.
Thanks.
May 16, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Blue screen on tv
I too have the same problem with the blue screen and also some dots in the center of the screen. I went to the sony site (www.sony.com) and found the answer. They will repair the unit until Dec 31, 2008. hope this helps
Nov 09, 2008 | Televison & Video
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Dec 14, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
