Question about The Computers & Internet
How can I reduce the amount of space my hotmail uses. I've cleared it and it's still using 1.19GB
4 Suggested Answers
athouba239
  • 122 Answers
SOURCE: the amount of space available is 0 and space used
there must be a hardware problem in the card, there are so much duplicate cards which can be used for a few days so beware of that kind of cards.
Posted on Jan 15, 2010
SOURCE: we are running Wavelink or Avalanche software on
The setting to hide the options menu and start bar can be done within the Emulation Parameters on a host PC.
From the main switch board run "Emulation Parameters" and then expand >>Emulation>>Display
This will give you a wide range of options which are useful to you:-
  • Hide Horizontal Scroll Bar
  • Hide Menu
  • Hide Vertical Scroll Bar
  • Start Menu
I would then set a key within:-
Menu Toggle Key
So that you could bring it up at any time when required. Most people use <CTRL><M> which is in fact <C><0x4D> (from memory).
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL +44(0)1202 620955
Posted on May 11, 2010
  • 4 Answers
SOURCE: Have water leaking out of bottom, clear water.
Is the water hot or cold? If cold you need to check all pipes and their couplings from the water tank to the boiler. If the water is hot, then check all pipes and couplings from boiler to brew unit and steam wand.
Posted on Aug 11, 2011
How to reduce data amount that takes storage space in facebook app on android 5.1 ? Cache can be cleaned everytime but data cleaning causes to reset all your log in information.
Hi Alito2123,
There is no way to reduce the data amount on the Facebook app. The developers are the ones who can reduce the data for the app. If you need the extra storage space use Swipe for Facebook or just use the Facebook mobile site on your mobile browser.
https://play.google.com/store/apps/details?id=com.happening.studios.swipeforfacebookfree&hl=en (Link to Swipe for Facebook)
Jun 19, 2016 | Android Cell Phones
Every other wash sd code come on
The SD error code is caused by using the wrong detergent or excessive amounts of detergent.
To correct the issue: Make sure to use HE detergent. Note: Using Non - HE Detergent will cause oversudsing and can damage the washer. Do not use too much detergent.
Note: If using HE 2x - 5x concentrate detergent, reduce the amount being used. The washer will try to run a mini-clean out cycle using cold water and a 5 minute pause to clear the suds. If this cycle does not clear the display and complete the cycle the clothing may need to be rinsed by hand and then rewashed without detergent.
Feb 18, 2013 | Maytag Bravos MTW6600T Top Load Washer
The bike wont stay running without the choke pulled out a bit, even after its warmed up. what could be causing this?
It sounds like your bike is running too lean, which is to say that it's not drawing enough gasoline through the carbs to match the air that's coming in through the air intake. Pulling out the choke reduces the amount of air coming in, creating a richer air/fuel mixture.
The most common cause for this problem is that one or more jets have gummed up slightly and so aren't able to pull through the right amount of gasoline. This happens a lot with modern gasoline if the bike has been permitted to sit for a while without being run (I've heard it can happen in only a few weeks; I've experienced it if I let my bike set 2-3 months). The idle jets that use use when you first start the bike or when the bike is just, well, idling, have the smallest diameters and are most prone to clogging.
The comprehensive solution to this problem would be to pull the carbs and completely clean them out. The whole bike will run better after you do that. The faster solution would be to clean only the idle jets, which occasionally can be removed from a carburetor while it's still in place on the bike. You might be able to do that for the two outer carbs on your bike, but I question whether you'd be able to do that with the inner 2 carbs.
Cleaning the jets themselves is the easiest part of the process--getting to them is the problem. The jets are made of soft brass, so you can use a a toothpick and/or a piece of very thin copper wire (it's softer than brass) to clear the jets. Simply using compressed air and/or carb cleaner is unlikely to get the crud out, though you can use all of these things together to get the job done. I sometimes soak the jet with cleaner, then poke it clear, then blow some air through it to get out any residual particles.
Pulling and reinstalling the carbs may require them to be re-synchronized. This, too, would make your bike idle and run better. However, if all you've done is remove, clear, and reinstall the idle jets, you may not have to synchronize the carbs, as you've done nothing to change their present settings.
Sep 11, 2011 | 1980 Suzuki Gs 550 L
Mailbox is near capacity. I'd like to keep my e-mails. How do I expand capacity?
If you use a free email provider such as hotmail, gmail etc... they do offer way more space if you pay. If you won't want to pay you could setup your email in outlook, windows mail, outlook express etc... and copy the messages to your local PC and delete them off the server. You could also delete sent items, spam and old emails to reduce your disk space.
Chris
Aug 10, 2011 | Computers & Internet
I think I have an internal memory problem. I can not take more than 2 pics with my sanyo vcp s1275, even after clearing the memory
My first impression is, this is a 12 meg camera and the picture file size will be pretty darn big and has maxed out your internal memory space. There are several settings on the camera for picture quality and I'm going to assume it's set for the finest. If you reduce this to "S" you will get a considerable amount more pictures but, the pictures will only be good for internet use maybe not printing
Dec 22, 2010 | Sanyo Xacti VPCS1275 Digital Camera
My e mail box is totaly full...Help me to receive emails again.
You must delete any unneeded emails if your given amount of space has reached it's capacity. I'm guessing your using Hotmail, if that is the case you can simply select all emails and hit "Delete" The same process applies to most other email providers.
Thanks,
Brandonmxb
Dec 14, 2009 | Computers & Internet
I need to reduce the fonts in word processor
With the graphic capability of computers and printers today, there are many fonts to choose from when writing documents.
  • Important category that fonts can be divided into are:
    • Monospaced fonts: Monospaced fonts are fonts in which every character uses the same amount of horizontal space, like this sentence.
    • Proportionally spaced fonts: Proportionally spaced fonts (also called variable pitch fonts) use up only the amount of horizontal space that is required for the letter. Therefore, the letter W would take up more space than the letterI. Standard HTML text font, like this sentence (bad example for those unfortunate lynx users :-), is an example of this kind.
Using these kinds of fonts requires formatting to be done correctly. Aligning text should never be done by using spaces. Since character width varies with proportional fonts, assume that it will never line up correctly using spaces. It is possible that on the screen it looks perfect, but remember that the resolution a monitor provides is not even close to the quality that a laser printer can produce. Even if monospaced fonts are used, spaces should be avoided in the event that the font is changed to a proportional font later. Instead of using spaces, use tab stops, indentation markers, and other features to align text.
  • Fonts can also be divided into:
    • Scaleable: Scaleable fonts, such as the popular TrueType fonts, are rendered by applying a fancy mathematical algorithm to represent each character. This allows the fonts to be used at any point size with uniform quality. These fonts are actually printed as graphics and therefore can be printed on any printer that can support graphics.
    • Printer: Printer fonts are the default fonts that come already installed with the printer.
    • Soft: Other fonts can be used by downloading soft fonts.
If there is the possibility that fonts used in the document are not going to be available on another printer, techniques such as embedding or substituting can be used.
Nov 05, 2008 | Gateway Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
thetraveler
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
