Question about Wega Coffee Makers & Espresso Machines
Hi there, have a wega mini and as of late the low water light flashes even though the reservoir is full. You cant operate machine while this is flashing. Any advice appreciated
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
SOURCE: low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Posted on Sep 28, 2009
  • 6 Answers
SOURCE: krups water level problem
I have the Krups FMF5 Gives a 'low water alarm' when it's full of water. Take a cheap multimeter from Wal-mart find which themal fuse on the heating element doesn't have continuity. Should be two of them on the unit, one on each side of the silver 'U' shaped element, They are covered in a white sleeve, with a metal retainer holding it to the element. They connect to the power wires White one and Black one going to the element. Mine was a SEFUSE rated for 214 degrees C, Less than $2.00 at Radio Shack I replaced it with a 226 degree C rated SEFUSE which is better than removing it entirely. (it is a safety fuse) I reused the old crimps holding it to the wires, Don't know if solder would hold up. Works like a charm.
Posted on Dec 11, 2009
  • 231 Answers
SOURCE: Machine will not dispense water even though
check the spray nozzles on top of the brushroll. these often clog. If those are clear could most likely be the pump as they fail frequently.
Posted on Jan 29, 2010
SOURCE: Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Posted on Feb 09, 2010
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Red light flashing even though water tank is full
try to check the floating magnet inside of reservoir tank.
Nov 06, 2012 | Sunbeam Cafe EM6910
After brewing a cup, lights are flashing and it needs to be unplugged to reset to brew
It's time to descale your brewer. Run a full reservoir of pure white vinegar through, and then a full reservoir of water, "brewing" and dumping one cup at a time. You might have to do two reservoirs of vinegar if you've never rescaled it before.
May 23, 2012 | Keurig Elite B40 Coffee Maker
Reservoir tank is full. green light flashing(indicating low water)
There is a water level sensor at the bottom of the tank, probably is stuck. Examine it very carefully.
Feb 03, 2011 | ECM Giotto Espresso Machine
Feb 08, 2010 | Zanussi TC7114W Electric Dryer
Low water light stays on
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
Inoperable expresso machine
Make sure the magnet in the water tank float up to the top.
Try to make a full cup of water (Tea).
Let me know if i can help you more
Best regards
/Mirran
Sep 08, 2008 | Saeco Incanto Classic Espresso Machine
Reservoir empty tank lights up but tank is half full of water
in the water tank you have a little magnet that magnet need to move up and down shake the water container to see that magnet move .thanks for using fixya
pierre
Feb 26, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Wega Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
