Question about Sewing Machines
Can I self thread an Esteem II machine that has a built in threaded?
yeroc
  • 397 Answers
SOURCE: The top thread will not grab the bobbin thread to complete a stitch.
its common, but easy to fix,,,ok......first things first, 1. bobbin in bobbin case correctly 2. machine threaded correctly 3. tension set around 3-4 upper 4. when was the last time machine was serviced
Posted on Jan 21, 2008
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 1116 Answers
SOURCE: How do you thread a singer esteem model 1732
http://www.singerco.com/resources/operation_basics.html
Posted on Mar 03, 2010
  • 1116 Answers
SOURCE: thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Posted on Mar 13, 2010
hazelgrace
  • 340 Answers
SOURCE: I lost my manual for
Try on this site.
http://www.sewingonline.co.uk/instructions/
Some manuals are free to view online and reasonably priced to download.
Posted on Aug 23, 2010
How to use a two hole sewing needle?
Sounds like a self-threading needle. Good for people who have trouble threading a needle or want a fast way to change threads.
Self Threading Needles Easy Threading Needles Miles Kimball
Oct 10, 2017 | Sewing Machines
Thread is bunching under fabric and I've rethreaded both the bobbin and the thread from the top multiple times.
Be sure your bobbin is inserted the correct way (this varies from machine to machine, so check the owner's manual). Bobbin tension is dependent upon this in most Singer machines.
Apr 03, 2015 | Singer Esteem II Sewing Machine - 2273
My pr 600 freezes
You might have Thread particles build up. Puchase canned Air for electronis and use it on a regular basic to clean your bobbin case area. Also when you change threads color always clip your thread near the spool and pull your thread out from the bottom near your needle. When you pull your thread through the top little pieces of the thread break of and fall into the chamber of your embroidery machine .
Mar 05, 2014 | Bernina Bernette Deco 600
Got a Singer Esteem 1732 and the bobbin test shows it has no tension at all (which shows on the stitch)
normally loose bottom stitches indicate a problem with the needle thread tension not the bobbin. try removing top thread completely and then rethread machine with presser foot down, if you do it with foot raised auto tension will not function
Feb 16, 2014 | Sewing Machines
Machine is un-threading itself.
try putting a piece of tape over the thread take up lever to keep the
thread from coming out of the thread take up lever
check your top thread tension also
Jan 25, 2013 | Singer Featherweight II 117
Singer esteem ii wont sew after the needle wouldnt go down and got fixed. when it does sew it skips stitches. what do I do?
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
if you can send me the model number of the machine,, I'll see if
singer has a free downloadable manual
Sep 11, 2012 | Singer Sewing Machines
Singer Futura II - Model 920 My bottom thread will not pick up and the top thread piles in a ball. I did thread the machine with the presser foot raised. Could there be a tension problem? Also where should...
you might try checking the needle, it could be damaged, bent, or blunt
then see if you can pick up the bobbin thread.
if you still can't pick up the bobbin thread it's possible that the machine could be out of time.. it would need to be serviced by a sewing machine repair shop & they can tell you if your sewing machine is one that has to be oiled or a self oiling machine.
Jan 20, 2012 | Singer Sewing Machines
Singer Futura II - Model 920 Sewing bottom thread is very loose, top thread perfect. Lost manuel in move. Dianne
This happens when we forget to have the presser foot raised when threading.
What looks like the fault of the bobbin is actually the top thread not forming a tight stitch with the bobbin thread.
When the machine is threaded with the foot down, the tension control is closed and the thread cannot enter the control as it should. When you begin to sew, the tension control cannot do it's job.
If the machine is already threaded, lift the presser foot and pull about 10" of thread from the needle, or re-thread the machine with the presser foot up.
Mar 14, 2010 | Singer Sewing Machines
How do i thread this machine
thread this machine by taking a strain of thread from the spool pull it to the thread guide on top left side of machine criss cross the thread when you wrap it around the thread guide pull thread down and loop it under the needle thread tension control dial bring thread up and loop it on the thread take up lever, continue down to the needle looping it first around the metal piece above it then through the needle it self pull thread to back of sewing manchine with the bobbin thread
Feb 12, 2009 | Brother LS-1217 Mechanical Sewing Machine
Janome MyLock 644D
Yes, the model I used had a self threading lower looper. Just put the thread into the guide and flick the switch
Nov 09, 2007 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
