Question about Singer Sewing Machines
Can I self-thread a Singer machine with a built in threaded?
Michaelle
  • 65 Answers
SOURCE: How do you thread the Singer QuantumLock 5 Differential Feed?
www.singerco.com/pdf/14SH654_threading.pdf
Its a different model, but most sergers thread the same way.
Posted on Mar 30, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
SOURCE: free download of singer overlocker manual
Jag har en industri overlock singer 81k73 Jag kan inte trä den
Har du några förslag
Posted on Oct 20, 2009
Maggie_B
  • 3 Answers
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Posted on Oct 31, 2009
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
How to thread singer model #AJ953185 sewing machine
To thread the upper thread of the sewing machine, place your spool on the spool holder. Then work from right to left after turning the hand wheel to bring the take-up lever to its highest point. Bring the thread to the left to the first thread guide and then go down. Bring the thread down and between the thread tension discs (down on the right and up on the left). Hold the spool tightly and pull the thread against the take up spring until the thread enters the retaining fork (at about 11 o'clock on a 12-hour clock) at the thread disc area. Pass the thread from right to left through the hole in the take-up lever. Bring the thread down through the guide on the face plate and then through the guides at the needle bar bushing and needle clamp. Put the thread through the eye of the needle (again from right to left).
AJ953185 is the serial number of the machine. It should be a model Singer 201 built after Nov. 6 1950. Most Singer manuals are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual to the 201 is http://www.singerco.com/uploads/download/651_201.pdf . For a picture of the upper threading diagram see page 11 (page 12 of the PDF). The bobbin threading pattern is on pages 14-15 (pages 15-16 of the PDF).
I hope this helps.
Apr 25, 2017 | Singer Sewing Machines
The self threader won't catch the thread
make sure the needle is inserted correctly into the needle holder
if the needle threader has worked before then there could be something
wrong with the needle threader
here is a link for a manual
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Dec 13, 2012 | SINGER 7470 Sewing Machine
Singer Futura II - Model 920 My bottom thread will not pick up and the top thread piles in a ball. I did thread the machine with the presser foot raised. Could there be a tension problem? Also where should...
you might try checking the needle, it could be damaged, bent, or blunt
then see if you can pick up the bobbin thread.
if you still can't pick up the bobbin thread it's possible that the machine could be out of time.. it would need to be serviced by a sewing machine repair shop & they can tell you if your sewing machine is one that has to be oiled or a self oiling machine.
Jan 20, 2012 | Singer Sewing Machines
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Sewing Machines Logo
11 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
