Question about Tools & Hardware - Others
Mastercraft portable thickness planer 55-5503-4 roller drive chain sorokets
jyackle5
  • 8197 Answers
SOURCE: Need a user manual for mastercraft thickness planer
I'd suggest calling 1-800-689-9928 and speaking with one of the customer service representatives
Posted on Dec 15, 2008
  • 6 Answers
SOURCE: my delta 13''portable planer is having a tough time feeding
If you are trying to remove too much material at one time, this will definetly happen. Try removing less material per pass.
Posted on Jan 07, 2009
efs_perpends
  • 1996 Answers
SOURCE: Delta 12 inch thickness planer blade change
Go to this link and at the bottom center of the page insert your model number. You will be able to download the manual for that machine.
Delta manual
If your question has been answered, or I fixed your problem, please take just a moment to rate this post...thanks!!
Posted on Mar 31, 2009
SOURCE: Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
Posted on Oct 18, 2009
  • 178 Answers
SOURCE: I bought a mastercraft planer
I did some searching and it looks like if you call 1-800-689-9928 they will be able to help you out. Let them know the date code, and its size. I really doubt they made more that one 12" planer that year. If that date code is like DeWalt or Delta, that should mean the 7th week of 1999.
Posted on Nov 22, 2010
I am looking for parts for a mastercraft thickness planer and was directed to this site...can you help?
I would suggest searching on line for your make and model of tool, you might be able to find an operating manual that should give you information for where to go for replacements.
Jan 08, 2017 | Crafts & Hobbies
Instructions for changing the chains on a mastercraft planer
Doesn't seem to be any instructions online or any videos. I did find this.
Please contact Mastercraft directly at 1-800-689-9928 to obtain a copy of the manual.
Jan 31, 2016 | Masonry Tools
I need all manuals for my SAC RS 63-S Surface Planer
Planers - Single - West Coast Machinery
www.wcmachinery.com/WCMACHINERY/myinventory.asp?...S...
Delta/Invicta RC-63-D 24" Planer in excellent condition. ... Table jack screw sprocketshave been replaced ... 16" single surface planer, - 5HP 208-230 volt single phase belt drive motor, - push ... with operation manual, - excellent condition but offered "as taken from service". ... 2240/440V, three phase S/N 203851 1974 year.Missing: my
Wood working machinery > Planers > Thickness planer (used)
www.machineseeker.com/2-106-65.html
Used Dickte SAC, further information will follow shortly... 2.500 EUR ... Thickness Planer, Thicknesser Huefner & Soehne 63 ... Thicknessing machine Sicar S 500... Working width: 500 mm Working height: 200 mm 2 speeds 2 Table rollers manualtable lift 4 knives - Safety shaft. ... Thicknesser mitTersawelle SAC RS 53Missing: my
Woodworking Planers - Southwest Machinery & Equipment
Dec 14, 2015 | Masonry Tools
I want to clean the drive components on my 12.5 in thickness planer, Mastercraft. What are the steps?
try posting this some where other than the car and truck repair forum? maybe the submarine screen door repair page.
Oct 30, 2014 | Cars & Trucks
I bought a mastercraft planer and do not have manual for it? I looked it all over it has no serial # and model # on the tag wear those # should be , there is only the date of manufacture and it is S9907....
Nov 22, 2010 | Garden
Need owners manual for Delta DW734 thickness planer
look on the right side of the page you can download the parts list or the manual
http://www.dewalt.com/tools/machinery-portable-thickness-planers-dw734.aspx
Nov 18, 2010 | Dewalt Planer (DW734)
Aug 06, 2009 | Tools & Hardware - Others
Dewalt735 Planer will not drive wide boards thru planer
I use denatured alcohol to clean the rollers on my Makita, and it doesn't seem to have harmed them over the years, but I do this infrequently. If your rollers are coated with pitch and or chips they won't feed well, no matter how they're adjusted.
(I don't think this planer has the capability to adjust the spring tension on the rollers, but I could be wrong.) You can consult the manual online at http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=22538&typeId=7605&documentId=21151
If you can attach dust collection to the planer it will probably help.
Also, the direction of the grain makes a difference when trying to plane boards as dense as poplar, (which has a kind of weedy, roey grain sometimes, that would prefer to tear out.)
For example, if you were feeding the board from right to left of the page, the grain on the side of the board should look like this//////// instead of this\\\\\\, which will have a tendency to tear out and jam the planer. If you can make sure the boards feed through in the right direction, this may solve your problems.
I heartily recommend the wax, as well. And possibly compressed air with a nozzle to blow chips aside.
Also consider the length of the boards and the effect of the drop weight on the planer's rollers if there is not an extension roller in place (or a worker) to hold the board as it makes its pass through the machine.
If you feed the board with the cup side down to begin with, taking light passes to smooth the top face, then flipping it over end over end and feeding the other side in the opposite direction, flattening first one face, then the other, you might have better luck.
Aside from all this, a surface planer isn't a jointer, which is designed to straighten & flatten boards, and portable planers in general won't perform as well as industrial models of the same capacity.
If you will continue to be running a lot of stock through your machine, you might want to consider investing in a used 13" Rockwell or Delta or some such cast iron planer, with rollers top and bottom to facilitate movement of course material. They aren't as portable, but might save time in the long run.
On a final note, there's no replacement for sharp knives. Even the best planer won't drive stock well when the knives get dull.
Best of luck!
Jan 18, 2009 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Feeding speed is erratic
Researching Your Model. The Rollers are Chain Driven, but this Planer is a V-Belt Drive. Any slippage of Your Belt? Are the Chains Loose?? (there's a Drive Chain on one Side, and a Driven Chain on the Other Ends of the Feed Rollers) Never Hurts to apply a "Light" Coat of Chain Lube to these Parts(Gears & Chains)
DO NOT SAND THE ROLLERS!! Cleaning them with Denatured Alcohol is OK ( I prefer Brake Parts Spray Cleaner Myself)...the Planer Knife Head & the Front & Rear Rollers all work together as a Unit.
What Thickness are You Trying to Remove?? Usually I don't like removing More than 1/32" per pass...
Have you contacted DeWalt Service?
Jan 08, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Nov 18, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
63 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
