Question about Health & Beauty
My sphygmomanometer stopped at 100 then skipped to 90
Mayo clinic website
The Mayo Clinic is at http://www.mayoclinic.org/ - and information on heart diseases and many other subjects can be found by using their Search box at the top of the page. It\'s a good search tool, uses "intelligent" searching, much like Google.
Aug 09, 2014 | Generic Heart Disease Awareness Aneroid...
The needle on the Sphygmomanometer gauge will not return to its zero reading. Otherwise it seems to function correctly.
This will happen sometimes, if the BP Cuff has been dropped and the gauge gets stuck. Have you tried tapping on the gauge with your finger, to get it to return to 0 ? Also. be sure the thumb screw air valve is fully open and the cuff is completely deflated. The gauge is easily replaceable, if necessary. Just contact the manufacturer of your BP Cuff or if you prefer Sphygmomanometer.
Thanks for choosing FixYa.
Sep 22, 2011 | Lifesource Aneroid Professional...
I have a blood pressure sphygmomanometer, how do you take a blood pressure reading and what is normal?
Much easier to go to a store, like Walgreens and get an inexpensive ( like 15 dollars) automatic wrist cuff blood pressure monitor, that will give you accurate and quick readings of your heart rate, and blood pressure, systolic and diastolic, automatically.
Apr 03, 2011 | Walgreens Health & Beauty
When should the timing belt be replaced
This is going to depend on which engine you have. The 2005 Accord 4 cylinder has a timing chain and is maintenance free. The 6 cylinder model has a timing belt and should be changed every 90 to 100 thousand miles which you do not want to skip.
Oct 26, 2010 | 2005 Honda Accord
We need to recalabrate the sphygmomanometer...how do we do that?
Hi mindy_blu
thats the problem with sphygmomanometer, however you may try this. open the glass part then try to re align the hand of the manometer. this will then calibrate your manometer.
Thanks
banaple
Aug 30, 2010 | Mabis Aneroid Sphygmomanometer, Large...
"Lumiscope"Sphygmomanometer needle begins on 80 mm/Hg and will not go any lower.How do I get it to go back to "o" ?
to let the needle go back to zero, find the air valve of the sphygmanometer then turn it counter clockwise or clockwise, depends on your sphygmanometer manufacturer.
Aug 11, 2010 | Lumiscope Aneroid Blood Pressure...
The needle is stuck on 120 on my sphygmomanometer
This problem may need to be escalated to a higher repair center a place like a precision measurement equipment lab. With it being a gauge I wouldnt recommend opening or doing anything to it since it is used to measure blood pressure.
Mar 10, 2010 | Palm Aneroid Sphygmomanometer By Mdf...
My new babylock is skipping stitches while sewing upholstery weight ultrtasuede
try using a heavy needle like a 90/14 sharp or 100/16 sharp and replace it often while doing thicker materials
Jul 10, 2009 | Brother SE-270D Computerized Sewing...
Health & Beauty Logo
16 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
