Question about GE Ovens
Jt912 ge profile does not turn on, no lights on display. I already reset the home's circuit breaker
    Top Expert:
  • GE Master
  • 78,257 Answers
More than likely you have a control circuit board failure.
Posted on May 19, 2017
GE Profile JT912 keep tripping circuit breaker
see this steps and fix it. God bless you
. Top element
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
2. Infinite switch
Another reason, why the element would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangeoven-repair-help.html#2-2#ixzz2aSmUeYiW
Jul 29, 2013 | GE Profile JT912 Electric Single Oven
Oven won't heat
major electrical problem. call a repair man asap!
May 19, 2013 | GE Profile JT912 Electric Single Oven
The probe doesn't work on my JT912 GE wall oven
Test Continunity for your Probe, if it has good continuity, then you have a internal issue with the Oven... More than likely, you are going to need a Technician
Apr 10, 2013 | GE Profile JT912 Electric Single Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    We had lighting come in and now our GE electric oven doesn't work. The range top still works but the oven display does not. Any idea's?
    Look for a reset or fuse on the unit. If lightening hit, the surge could have wiped it out, as you already know. But hopefully GE put a fuse or breaker in the unit. You just have to find it, if it exists.
    According to GE, a diagram is located in behind the control panel. If you can safely remove it (CIRCUIT BREAKER OFF) you may find the protection devices that GE has in place. You may also
    find the fuse or breaker hiding in there too! Good luck.
    NEVER ACCESS AN APPLIANCE WITHOUT FIRST TURNING OFF THE CIRCUIT BREAKER
    OR UNPLUGGING THE UNIT. BE SAFE.
    Apr 01, 2011 | GE Profile JTP18 Electric Single Oven
    Control panel continously beeps with message to
    Could be a faulty control as you suspect but also may be a bad keypad. If the "start" button has no effect I'm suspecting the keypad first.
    Best Regards,
    Bruce
    www.fixyourboard.com
    Jun 19, 2010 | GE Profile JT912 Electric Single Oven
    Ge Profile built-in 27 inch wall oven -- When I
    f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
    Jun 18, 2009 | GE Profile JT912 Electric Single Oven
    My oven does not work at all.
    Put a lanp in the same outlet that the stove is hooked to, If the lamp does not light then you popped a circuit breaker for that line. If the lamp works then you blue a fuse that is probable in the control panel of the oven. I hope this helps
    Jan 21, 2009 | GE Profile JT912 Electric Single Oven
    GE JT912-30 single wall oven "help" with F7 - F0 error
    I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
    Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
    Ovens Logo
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
