Question about Swingline Office Equipment & Supplies
Swingline optima 45 was out of staples, when replaced the magazine will not close.
4 Suggested Answers
SOURCE: Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
Posted on Oct 26, 2010
richroth
  • 9472 Answers
SOURCE: Someone loaded regular staples into
The Optima 45 is a very touchy stapler. Either you have a staple stuck or the unit is damaged. There is a five year warranty on the stapler so if you have had under five years it will be replaced for free. Here is the contact number. 1-800-541-0094
Posted on Jul 21, 2011
crossflowspe
  • 36 Answers
SOURCE: My Optima 45 has stopped stapling. I cleared the area of crimped staples but it won't punch out a staple. What can I do?
Try to take all the staples out then put a small amount of "Two in one oil" as it is very fine oil. Once you have done this wipe off the excess oil if you have a lot spill out wipe with a rag & use the rag to wipe over the underside of one row of staples.
leave overnight & try to use this again with the slightly oiled staples this should remove any oil left then see if this does the trick. (Note I hope you have the correct staples for the machine of course.) Best Wishes Malcolm
Posted on Jun 02, 2015
There may be a reset button / leaver open it back up have a look around and see if there is any thing like a leaver that needs to be pushed into place for the machine to recognise it has been reset.
Feb 06, 2015 | Swingline Optima 45 Electric Stapler
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Staples will not come out of the stapler.
Did you use Optima brand staples? If not, the stapler will not work correctly. You must use their brand of staples or it will continue jamming, and giving you problems. The staples typically found right next to the Optima staplers in the office supply stores. They come in a rectangular metal box and are labeled Optima staples.
Sep 18, 2013 | Swingline Optima Electric Stapler 45 Sheet...
No staples coming out of machines
The Optima line of staplers do not work without jamming continuously unless you use the Optima brand staples. They can be found in the store next to the Optima staplers in a rectangular silver box, and will solve you problem instantly. There is no other brand of staple that will work in this line (I tried numerous), but once you purchase the Optima staples, problem solved, and you'll love it!
Someone loaded regular staples into our Swingline 45 Optima now it will not work when loaded with the correct staples.
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Jul 21, 2011 | Office Equipment & Supplies
How do I open the swingline optima model # 8784x to reload staples?
I couldn't open my Swingline Optima model 8784x either. Their website wasn't helpful except they mention you can change staples "with the push of a button." Button, I thought. What button? In the picture, there's a black button at the back end of the stapler. Mine is missing! The button, if it were there, would press down on a metal tab, releasing the staple slide which pops out the front. Insert staples, push it closed, you're done! I used a letter opener to push down the metal tab.
Jun 27, 2011 | Staples Swingline® 36115 Staple Guns Tools...
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Mar 10, 2010 | Office Equipment & Supplies
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
