Remotes and door keypad now won't work / sync on my powerlifting 900 genie garage door opener
My genie powerlifting 900 stopped closing, so I had to unplug power and then reset the limits. Now both remotes won't work so tried to sync by pressing the main button and the remote but nothing (just purple keeps flashing until red time out) and the keypad now won't work either. Have tried changing the remotes to type 1 and 2 (green flash or red flash when pressing) but still nothing and changed battery in case weak!!!! please help
    Top Expert:
  • Televison & ... Master
  • 78,257 Answers
I think your garage opener has failed.
Posted on May 19, 2017
Garage door closes but doesn't stay closed
if nothing is obstructing the door then there are 2 possibilities:
a) your limit switch for closing is too low and the closer detects the motor stall as the floor is reached, then opens in case it's a kid under the door.
b) your tracks and garage door are mis-aligned, causing excessive force to trigger the reversal. Make sure the door closes easily by hand.
Jun 19, 2015 | Genie Powerlift 900 Garage Door Opener
Genie 900 door operator
hello,there is an adjuster on the side of the motor,also check that the micro switch[if fitted on your particular type} is 'clicking' and actually in contact with the arm as it revolves closed. hope that helps, cheers
Jun 02, 2014 | Genie PowerLift 900 1/2 HP Screw Drive...
Why won't my Genie garage door opener close without going back up.
So it seems the Main garage door unit on the ceiling is ok. The problem is with hand held unit. Usually the circuitry is ok. Try changing the battery. It has helped me. Also make sure the sensor on ceiling unit is not blocked ad is free of cobwebs.
Jun 26, 2013 | Genie Company Garage Door Parts Genie Gwkp...
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
Genie model ACSD1G will not program to Linear door opener model # LD033.-- need help doing this.
Most of the time, keypads and remotes are not compatible with other manufacturers. You would be better off getting a universal keypad, which should work. Double check the older opener to make sure it is on the list of compatible devices.
Also, make sure you check the balance of your garage door periodically to make sure your springs are counter-balancing the garage door properly. If not, the lifespan of the garage door opener will be substantially shortened. Click here for a how-to video.
Feb 28, 2011 | Genie Company Genie Gwkp Keypad...
Genie Screwdriver, garage remotes won't work, batteries are fine.
Your receiver has quit working. A call to your local Genie dealer should get you back in business.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
Top Televison & Video Experts
