Question about The Audio Players & Recorders
Trying to find the Ultronic small "Bose" shaped radio that came with a Time magazine subscription. Where can I find? Leslie Holliday
SOURCE: ultronic WS-9 radio/clock/calculator is there a light?
need a manual for a Ultronic clock radio calculator model WS-9
Posted on Jun 24, 2011
SOURCE: I have the S1721 Travel
I came home and found a weird display showing 12 00 and ______f. Nothing worked, even when I unplugged it and took the batteries out. (I really, really like this clock radio so I wanted to find a solution).
I looked for a "reset" button and found one in the back inside the battery case (you have to remove the battery case cover). I took a pin and pressed it into the reset slot. I had to do this several times, turning it on/off and pressing several buttons and plugging, unplugging the clock/radio. It cycled through several times, then slowly the functions started to return, almost one function at a time. After several cycles of this, it turned itself back on and started working again!
Posted on Sep 07, 2011
SOURCE: Does anyone have instructions for
Here are the instructions that came with my clock.
Posted on Oct 30, 2011
  • 12 Answers
SOURCE: how do I cancel free trial to Diabetic Living and Prevention magazines?
The publisher's policy on how they treat cancellations is info you'll have to get directly from them. You can usually find some of that info in their "masthead" which is normally near the Table of Contents. You'll find the location, contact info, etc of the publisher which will allow you to contact them. Perhaps a web address too. But every magazine makes their contact information accessible, so just call them!
Posted on Jan 02, 2015
AndrexT
  • 20350 Answers
SOURCE: I want to cancel my subscriptions to TIME magazine
Cancel here online
TIME Magazine Returns Policy
Posted on Dec 20, 2016
How do I cancel my magazine subscription?
Much of the time your subscription is for a year or two. Close to the time your subscription is up the magazine publisher will send you a renewal form to renew your subscription. To unsubscribe you just throw the renewal form, if you don't want to renew the magazine, after you read it, in the trash. They may say to do nothing if you want to renew; at this time you'll have to say you want to cancel the magazine or it may automatically be renewed. If you want to cancel your magazine subscription mid-year, you'll have to find the publisher's address somewhere in the magazine and write them to say you want to cancel. They may or may not give you back any of your subscription money.
Jan 19, 2015 | Computers & Internet
I have the S1721 Travel Soother Radio Alarm Clock. It has stopped & a radio technician said it can't be fixed. It is THE best radio on the planet because it has a radio timer. I cannot find anything...
Dec 01, 2010 | Sharper Image Travel Soother 20 Clock...
My CD changer cartridge is jammed in the unit
Peel the top off the unit using a small flat head screw driver. You may break the glue or the tabs are like the one's you'd see on a cars door panel. (xmas tree shaped spears). Once this is removed you can see the CD and the top of the changer. Under the unit there is a molded message that says Manual magazine release. Go into the thin slot with an ice pick and push to the back of the "U" shape. You can feel that it is spring loaded. This will release the cartridge.
Jun 01, 2010 | Bose Lifestyle 20 System
Ultronic WS-9 radio/clock/calculator is there a light?
Dec 15, 2009 | Audio Players & Recorders
I can not get the Magazine to release. I see where it say's Manual Magazine realease, but can't tell what to do. Please help Darrell Mack
Hi
Thanks for using FixYa. First of all please check that the speaker cables are not damaged and the connections are secure. Reduce the output level from any external components connected to the music center. Make sure the audio input cable is firmly seated in the music center SPEAKER ZONE 1 jack and the multi-pin connector on the other end is firmly seated in the Accustoms module AUDIO INPUT jack. Check the cables connecting the Jewel Cube TM speakers to the Accustoms module. To restore communication between the music center and the speakers turn the music center off for ten seconds, then on again. Check the connections for any external components. Make sure to select the correct source for the desired input. Be sure the CD is placed correctly, label-side up, in the magazine, and the magazine is inserted properly in the music center. Increase the volume. Check to see if MUTE is lit on the display. If it is, press the MUTE button on the remote control to un-mute the sound. Disconnect any headphones. Connect the FM and AM antennae. Check to see if the play symbol in the display is lit. After pressing the CD key, wait a few seconds before pressing PLAY. Make sure the magazine is properly inserted. Check to see if there is a disc in the magazine, label-side up. Display shows a flashing box for a disc that is label-side down or cannot be read. There may be dirt or dust on the CD. If so, clean the CD. Eject the magazine and try loading the CD again. A display message “E01” indicates a mechanical error. Unplug the music center. Reconnect power and try again. If “E01” reappears, call customer service.
If the CD stuck again as you stated in your earlier comments, then you need to use a small and long screwdriver to reach the notch. Now turn the media center upside down so that the "Manual Magazine Release" is in your upper right hand. Locate the two small rectangular "Open Slots" on the side. You need to use the top slot. Use the screwdriver and push the little "U" or "Y" Shaped metal upward which is just below the manual release. The magazine will come out.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 16, 2009 | Bose Lifestyle 20 System
Question
Hi, Underneath the unit you will see a small slot and "manual cd eject" embossed on the case , a jewelers screwdriver or darning needle or anything stiff and thin to pull down the wire lever inside the slot should do it.
Dec 28, 2008 | Audio Players & Recorders
How to open the case?
Hi- I had to also remove the CD cartridge. A Pain! You can easily remove the case cover. You need to carefully remove the LED lens from the front by using a small putty knife to depress the expansion pins on the right and left sides and pry the lens cover up. Then, use the putty knife to lightly pry up the aluminum top cover. There are 4 nylon pins affixed to the aluminum cover by double stick tape. They are approximately 1.5" from the corners. Lightly pry up each corner to remove the top cover and you are in. There are no screws. Don't gorrilla the thing or you will bend the aluminum. Cheers!
Apr 13, 2008 | Bose Lifestyle 20 System
Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Jul 29, 2007 | Bose Lifestyle 30 System
13 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
