Question about Garden
My bolens 160 won't start after I turned it off
Bolens manual
http://www.freeproductmanual.com/bolens-bl150-manual/
Aug 17, 2014 | Heating & Cooling
Bolens 4.5hp mower won't start
did you hit a rock? and shear the key that times the flywheel to the crankshaft check for spark the coil might have failed
Jul 01, 2012 | Briggs & Stratton Briggs Stratton...
Blowing fuses in my bolens ST140
when is the fuse blowing while cranking or when just turning on the key when the blades are turned on
Jun 09, 2012 | Garden
Bolens riding lawnmower st100 pto won't engage?
check for power to the clutch if yes the clutch could be bad or a wire going to it if no power check the safety switches
May 17, 2012 | Briggs & Stratton Garden
17.5 hp bolens lawn tractor motor turns slowlyand will not start. new battery, starter works. what is valve adjustment proceedure?
check the battery cable bypass them with jumper cables that engine uses a lot of amprich to spin it over valve adjustment would change all at once but i set mine to .006 when the opposite valve set the other one
May 11, 2012 | Ariens Garden
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
1993 Toyota Camry won't restart after driving unless waiting hours. The starter doesn't try and it's brand new. It always starts cold and if you don't drive it, you can turn it off and restart it over
i'me asumeing the batt is ok....turn on lights, do they dim when you try to start engine? if not .bad selonoid on new starter..was it rebuilt? it happens. Billy Starr
Dec 27, 2011 | Cars & Trucks
I need a bolens 516c snowblower owners manual
Here's the link to the manual. Give it about 20 sec to load the page.
http://lawnandgarden.manualsonline.com/manuals/mfg/bolens/76901274d.html?idRes=6770867
Oct 31, 2011 | Garden
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
