Question about Garden
I have a Kohler Courage 24HP that has been running fine for 6 years. Yesterday the engine began cycling at low RPMs. Sprayed some cleaner on the carburetor linkage...did not help. Suggestionss??
    Top Expert:
  • Garden Master
  • 44,580 Answers
Indicates water or dirt in the catby
have it overhuled and cleaned out
Posted on May 19, 2017
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Kohler engine troubleshooting
check condition of air filters. check float level and flow of fuel to carby.
May 27, 2013 | Garden
Toro timecutter mower motor upgrade
90% of vertical shaft engines use the same pattern only seen a couple that one hole is off place
Sep 13, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
Left side drive began to shake and rattle then gradually lost all function. Right side working fine.
each side has is own pump and drive motor check the fluid level and then you will need to remove it and either replace it or rebuild it
Jul 30, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Cub 1550 with kohler courage. Runs fine and then loses power, runs erratic and starts to backfire. Cleaned carb and fuel pump and ran fine for 30 minutes and then problem started again. When this occurs,...
Replace fuel filter after cleaning tank thouroughly, to clean tank remove fuel line at carb. Drain all fuel then leave line loose until you flush tank with carb. Cleaner then blow out tank with compressed air. Now install new fuel filter and check your fuel can for trash and water better yet just add fresh fuel.
Aug 12, 2017 | Garden
Engine RPMs keep going up and down, not a steady engine speed.
By your description, you have a Briggs & Stratton carb-on-the-tank engine?
Replace the carburettor diaphragm. It's either holed or work-hardened. Costs pennies.
May 12, 2010 | Mg International MasterCut 20" 123cc Push...
Dodge ram 1500 engine rpms surge at freeway speed
those sensors could cause the issue, clean the MAF 1st, also clean the idle system using the following procedure, the IAC can cause cruise surge. I use this to cure these problems all the time.
Here is the most common cause of surges and stalls and low idle, it is the idle speed control air-bypass valve (IAC) and throttle valve, they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Jan 13, 2009 | 2001 Dodge Ram 2500 Truck
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
