Flashing lights: Operation light flashes 8 times and the timer light 4 times on a floor mounted heat pump
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
SOURCE: i have a Fujitsu ASTA24LCC
Check your filters. Manual says they need to be cleaned every two weeks under normal operation (and in my case more often during renovations). It seems it may not take much to limit air flow enough for the indoor unit to trip out. Hope this helps.
Posted on Aug 24, 2008
hvac1960
  • 2133 Answers
SOURCE: Operation and timer light flash
Please cancel your timer setting by reset the power. And also remove battery from your remote and reset it. Now start your unit.
Posted on Dec 14, 2010
jasondonohue
  • 6 Answers
SOURCE: Timer light on fujitsu heat pump flashes not heating
the light flashing indicates there is a problem. you can try reseting the system by turning the power supply off and back on again 30 sec later, if the same thing happens you need to count the number of light flashers and that relates to a fault code
Posted on Jun 20, 2012
ercupa190
  • 12223 Answers
SOURCE: my friedrich mw18y3f dosent work any more, the operation light and the timer light flash together 4 times and after it's the timer light that flashes 4 times alone. can someone help me
1( replace batteries with FULL charge and the same type alkalines do not mix
2( clean the contacts batteries very well c.cleaner
3)retight the springs contacts with long pliers for better contacts.
4) open the remote control for to clean the keypad from dirty, oxide, corrosion and bad contacts.
5) proceed to reset the code, and try again.
However if do not work, you must go to the repair shop Tv for fix it.
God bless you
Posted on Oct 09, 2012
Fujitsu heat pump error code for floor mount asta18lcc.
if they both flash 5 times it means Compressor Failure. Not a great fault to have. could either be the inverter board or could be a stuffed compressor
May 26, 2014 | Heating & Cooling
LG aircon operation flashes blinking light 8 times and then shifts to timer light flashes blinking light 4 times
Sounds like a 48 code. (There is no 84 to my knowledge).
Outdoor unit coil outlet (liquid line) thermistor has disconnected or has shorted out.
call a LICENSED hvac repairman
Apr 21, 2014 | LG LS-L1210CL Mini Split Air Conditioner
My friedrich mw18y3f dosent work any more, the operation light and the timer light flash together 4 times and after it's the timer light that flashes 4 times alone. can someone help me
God bless you
Oct 08, 2012 | Friedrich Heat Pump, 18, 000 BtuH, Wall...
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
Heat pump won't start, red light flashing
I do warranty work for Fujitsu ACs. You need to be more specific with the "Flashing" How many flashes of both the timer, and operation light are there? These relate to problems/faults. Take note next time and post it back here.
Feb 27, 2010 | Fujitsu Heating & Cooling
Fujitsu ASU9RLQ
Mar 10, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
