Question about Retail Supplies
My coin sorter is placing all coins down the 50 cent slot and not assigning them to the 25, 5, 10, and penny slots. Hope this makes sense
  • 80 Answers
SOURCE: stuck plastic coin inside drive slot
Hello my name is Tim Ehrhart and it sounds like you get the joy of taking a ps3 apart. I have a link to a great site that will walk you step by step how to do this with out messing anything up. This takes a little while but with a little time and patience you will be able to do this yourself. http://www.consolezombie.com/PS3/Sony-PS3-Disassembly-Tutorial.html please leave me feedback as I am new and trying to get a awesome rep.
Posted on Mar 16, 2009
chris252
  • 84 Answers
SOURCE: Coins placed in the disc slot of the Wii.
I would not advise using the drive if there are any loose objects inside. Doing so would void your warranty, cause damage to the wii, and possibly even bodily injury. If the disc should come into contact with the loose object while spinning at high speed, the disc could shatter and the shards may actually break through the drive casing.
A loose object, if it catches something traveling at high velocity, can easily damage the casing and the wii remember
The only practical solution is to remove the drive from the wii and obtain a replacement. It would be prohibitive to try to fish out the loose object, since you might damage the internal components in doing so. you will need to call Nintendo ( 1-800-255-3700) and see if they can fix it or guide you through taking the disk drive out
I don't think they will slide out if you turn the MBP on edge. I would take it to the Apple store and be prepared for a nice bill. I hear kids also do this in the disk player in the car to get it fixed It won't be cheap, I 'm afraid,
At the very least the drive will need to be removed, I fear. It may actually have to be replaced. A few hundred dollars, I would guess.
Good luck
Posted on May 06, 2009
Testimonial: "I sent it off to Nintendo to fix for $76.00. Not as bad as I thought."
  • 38 Answers
SOURCE: Bally coin slot machine wont let the handle pull
THIS IS DOCTOR FIX. MY BUSINESS IS GAMING REPAIR. (JUKE BOX=PINBALL= SLOT MACHINES
BOWLING =POKER, FOR 68 YEARS.) IF YOU HAVE NOT SOLVED YOU PROBLEM, I ASSUME IT IS ELECTRONIC, NOT MECHANICAL. IF MECHANICAL , LET ME KNOW, I WILL TELL YOU WHAT TO DO.
ON THE ELECTRONIC, OR ELECTRIC (NO COMPUTER)
THERE IS A BAR MOVES ON TO THE CAM ON TOP OF THE CATCH, ABOUT 3 INCHES ABOVE THE BOLT THAT HOLDS THE ARM IN PLACE, WHEN A COIN IS INSERTED INTO THE COIN SHOOT, THAT METAL BAR ENGAGES THE RATCHET , TO SPIN THE WHEELS. DOES THAT HAPPEN ON YOUR SLOT.? OPEN THE DOOR PULL THE WHITE SWITCH THAT CLOSE WHEN DOOR IS CLOSED (OUT) THESE ARE A THREE POSITION SWITCH.
IN-HOME JUKE BOX REPAIR
SEYLEVITT@JUNO.COM
HOPE IT HELPS.
Posted on Jun 29, 2009
prawinmv22
  • 106 Answers
SOURCE: how do I remove as coins stuck in cd slot
hi....
there is only one way to remove the coins from the cd slot.....you needed to go for the service center....there they will disassemble it in few seconds and take out the coins and reassemble it very carefully.....so that your cd player also doesn't get any damages in it....it will cost only very little....
if you are satisfied with my solution then rate for me.....
thank you for using fixya.....
Posted on Jul 20, 2009
SOURCE: I have a Whirlpool coin operated top load washing
I hate this
try insert another coin
if not you will have to run a wire through and a frictioned and magnetised coin might help
if you can you will have to dismantle this part in trying to release it
Posted on Sep 27, 2009
How many combinations of 56 cents are there?
Great question.
You could start with the number of quarters, which can be 0, 1, or 2.
If there are 0 quarters, then you only have dimes, nickels, and pennies to worry about. You can have 0 to 5 dimes. There can be 0 to 11 nickels. For pennies, there can be 1, 6, 11, 16, 21, 26, 31, 36, 41, 46, 51 and 56.
Time to work out lots of combinations!
Sounds like a summative project for a data management or statistics course or a great computer programming assignment;)
Good luck,
Paul
Find all combinations of coins when given some dollar value
Jan 16, 2016 | Office Equipment & Supplies
FS-4DA coin sorter won't count pennies
The good news is that the unit is functioning, it's just counting pennies. I had the same problem with quarters and is a fairly easy fix. I won't get into any disassembly details, but you'll need to gain access to the infrared detectors (mounted to the motor assembly) and possibly the emitters (mounted to the front panel LCD display/push button board). Also, please be careful not the damage the wire harnesses when removing the top cover. Once apart, you can use your cell phone camera (which is sensitive to infrared) to see a purplish/white glow from a healthy emitter. Compare the penny emitter to the others and chances are it will have a lower output level and need replacing. If the penny emitter is strong, then check the detector with any infrared remote control( TV, cable box...) by pointing the IR remote control towards the penny detector and pushing any of its control buttons. This should make the penny amount count up, and fast too, as the remote sends out IR pulses while a button is being pushed. If this test doesn't increment the penny count, then the penny detector needs replacing. But before you do, try this remote control test on another known good detector to verify your findings. Please keep in mind that other malfunctions besides an emitter and detector could be the cause of your problem, but given the FS-4DA circuitry, the odds are extremely high that you have a bad emitter 1st, then a detector 2nd, as emitters are known to degrade over time and especially when continuously powered, as in the case of a switched 'ON' FS-4DA. FYI...IR emitters and detectors can be purchased from Radio Shack. Good luck and take care not to electrocute yourself when powering the unit with its cover removed.
Feb 21, 2014 | Royal Sovereign Fs 4DA Model Fs 4DA Coin...
C100 Coin Sorter & Counter C-100
Coin sorters have to be able to handle a variety of coins in a variety of conditions. The one intended for home use are not very accurate even when new and sorting accuracy declines with age. The only practical "fix" is to take a technological step backward and sort coins manually.
Nov 12, 2013 | Cassida C100 Coin Sorter & Counter C-100
We have a 50 cent coin stuck in the end of the drain. 20 and 5 cent came out but 50 appears stuck, I can feel it but doesn't look like it will fit out. Do you think we will have to dissasemble the...
No brand No model. If you can see the 50c coin which is the problem, a handy hubby should be able to figure out how to fix the problem. Sometimes you have to 'cut out the problem'..
TIP Make sure the 50c coin hasn't got between the drums in a front load situation, because that situation can cause BIG problems.
Good luck
Nomess
Sep 09, 2010 | Washing Machines
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    Change the number of coins to operate
    you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
    Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
    SEYLEVITT@JUNO.COM
    HOPE IT HELPS.
    May 03, 2009 | Bally Walk In 9 8"" X 19 3"" X 7 6"" high...
    Coin operated washer and dryer
    remove the coin slot out remove the slug used to plug the coin slot
    Feb 24, 2008 | Washing Machines
    Retail Supplies Logo
    26 people viewed this question
    Top Retail Supplies Experts
    Electroboy
    Electroboy
    Patrick Tinashe...
    Are you a Retail Supply Expert? Answer questions, earn points and help others
