Question about Swisher Garden
Spindle replacement for 1997 swisher trailmower - need part number. Will probably need whole assembly?
4 Suggested Answers
  • 4 Answers
SOURCE: cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Posted on Jun 26, 2009
  • 280 Answers
SOURCE: I have a pull start swisher trailmower. The cord
the cord could be tanlged up, pull it all the way out and make sure it is round the "bobbin" and not slipped off the side on the shaft. you wight be able to slip it back onto the bobbin with a screwdriver or piece of hooked wire - Also you are using the proper mix of 2 stroke and fuel?, 50:1 fuel to oil, or more for older.worn engines, say 40:1 for old engines, they run better like that - smell nice too.
apart from that... oil the puller mechanism, normal engine oil will do the trick - it can only help.
Posted on Jan 26, 2010
wvbiker59
  • 23 Answers
SOURCE: I need replacement parts for my 60
I RECENTLY BOUGHT A USED SWISHER FOR $700 13.5 HP 60 INCH I BELIEVE THE MODEL IS 1340D? I'M HOPING I DIDN'T GET RIPPED OFF AND THIS IS SOMETHING SIMPLE..I THINK THAT'S THE MODEL NUMBER I'M NOT EXACTLY SURE THE STAMP O N THE SIDE ISN'T TO LEGIBLE , ANYWAY WHEN I SPRAY STARTING FLUID INTO THE AIR FILTER IT RUNS BUT THEN STOPS. IT HAS A NEW BATTERY, FUEL LINE AND FILTER AND I JUST TOOK THE CARBURETOR OFF AND SPRAYED IT OUT WITH GUNK CLEANER TO NO AVAIL. THE FLOAT BOWL WAS REALLY CRUDDY. I'M WONDERING WHERE I CAN GET A NEW CARB? ARE THEY AVAILABLE? IF SO WHERE? THANKS
Posted on May 14, 2016
Swisher manual
I BELIEVE IT'S 22 INCHES I JUST REPLACED MINE, SEARS HAS THEM OR YOU CAN GET THEM AT SWISHER.COM WITH PART #6046 FROM THE MANUAL OFF THEIR WEBSITE. I'M FINDING I HAVE TO ORDER EVERYTHING SO I'M GETTING 2 OF WHATEVER I NEED AT THE TIME
Jul 29, 2014 | Swisher 60" 13 Hp Trailmower #T1360h
How to replace belt
SWISHER 44 Finish Cut Trailmower Tension assembly belt bra Parts Model...
If you look at the diagram ( zoom in) part #94 , idler spring, is what puts tension on the belt.
Jun 07, 2014 | Swisher 44 Iinch 11.5 Hp Trailmower...
What size belt for my swisher 44" pull behind
I just replaced the belt on my 44" Trailmower and since I had to get it up and running without waiting for new Swisher 4220 belt I found an ordinary V-belt 1/2"X72" whith overall with of 74" works OK
Jun 28, 2011 | Swisher 44 Iinch 11.5 Hp Trailmower...
I need replacement parts for my 60" Swisher Trailmower / model T1360B1 When I went to the Swisher website, it says its obsolete. Where can I get parts.
May 05, 2010 | Swisher 60" 13 Hp Trailmower #T1360h
Jan 26, 2010 | Swisher 44 Iinch 11.5 Hp Trailmower...
I need a belt diagram for swisher t60 trail mower
Here's the manual for it - section 12 belt replacement, page 16. It goes over all pulleys except the idler - it goes under the idler pulley.
Aug 30, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Cable streched on swisher trailmower
Jun 22, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Garden Logo
11 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
