All of my lights are flashing ,I changed outlet and still flashing.will not let me power off
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
HELLO MY kdf-e55a20 tV IS NOT WORKING. THE GREEN LIGHT FLASHES 6 TIMES THEN IT FLASHES RED 6 TIMES
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The Lamp light blinks when the Lamp requires replacement.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the power light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
This indicates that there is some kind of audio problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 11, 2011 | Sony KDF-E55A20 55 in. LCD Television
My standby/timer light is flashing and will not turn on.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
Jun 02, 2011 | Sony KV-27S66 27" TV
Standby time light on and keeps flashing
May 21, 2011 | Sony FD Trinitron KD-36XS955 36" TV
TV turns itself off and power light flashes green
May 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Red blinking light
Aug 14, 2010 | Sony KP-53HS10 TV
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Lights flashing
- make sure cartridge cover is securely close
- power cycle the printer
- try to plug in directly to the outlet
- unplug the power cable and plug it back in
pls let me know if same issue persist!!!
Oct 05, 2008 | Epson Stylus C88 InkJet Photo Printer
Flashing lights
That flashing pattern is consistent with a stuck carriage. Here is a copy/paste from HP concerning the 5000 series and your flashing lights.
Issue
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Close the cartridge flaps after removing the ink cartridges.
4. Turn the printer off, then on again.
5. Replace the ink cartridges.
6. Close the top access door. Issue
The Resume light continues to blink after the cartridges are released.
OR
The carriage is stuck or makes a grinding noise.
Solution
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
5. Take out the cartridges and close the top cover.
6. Reconnect the power cord to the back of the printer. Plug the power cord to the wall outlet.
7. Open the top cover, reinstall the cartridges, and then close the top cover.
Oct 23, 2007 | HP DeskJet 5550 InkJet Printer
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
