Coffee Makers & Espresso Machines Logo
Leslie Anne Posted on May 19, 2017
Lately when i use my tassimo to make a latte coffee it leaks out from where u put the disk in. I noticed the seal seems to be broken. Could that be the problem?
5helpful
My tassimo lid wont open and cant get my disc out
My tassimo lid won't open I put the milk pod in for a latte it made a noise and some milk spilt out and it won't open turned the machine off for a few days n the lid still won't open is it now broken ? As only had it for a few months
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Why is tassimo leaking and it's brand new!
if it's still under warranty, I suggest taking it back, it could have a crack or a seal damaged.
No liquid coming out
It's probably Blocked. Contact Tassimo in your region for a repair center. they are very good.
3helpful
No water comes out of the tassimo T40 when making a drink.
I found that the cleaning disk puts through the correct amount of water but coffee disks don't. Suspect then that the problem is related to the pressure or flow from the system when disks are in , or the cutter part. I have now bought a new machine. I can swap this part across and check to see if this issue with non delivery of correct quantity of water its related to the suggested worn cutter.
My tassimo has just been descaled but when making lattes, there is still creamer solution left in the pod when the machine has finished
Have you tried shaking the pod before use?  Also, they don't work as well after they have been frozen, just in case yours were.
6helpful
2answers
When making lattes, only half the milk is used?? It also is not making the correct "sound" during the foaming process. I have used descaler but this has made no difference.
I just corrected this problem. I diluted some CLR (calcium, lime and rest remover). I put the diluted solution is the water reservoir, I ran it through using the cleaning disk, I re-dumped the solution back into the reservoir. I did this repetitively for approx 30 minutes, then I left the machine alone for 30 minutes. I then ran a few reservoirs of clear water. PRESTO! I just made a latte that used ALL OF THE MILK PRODUCT....IT ALSO MADE THE NEAT LITTLE NOISE! A bit time consuming but it worked!
1helpful
6answers
Cappuccino and latte T-discs do not empty out.
Same problem, used descaler as instructed and all was solved and brewing back to normal:)
All lights flash
Try cleaning the light sensor that reads the barcode on the disk. If it is dirty, some of the discs won't work. Also, try holding the water canister down with your hand while the coffee is brewing. If the canister vibrates, the lights may blink.
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
