Question about Samsung Televison & Video
PN64D8000FFXZA shuts down on its own and will not turn back on, but eventually does after unplugging for awhile or removing the back cover and then putting it back together.
I own a Samsung Plasma tv, model PN64D8000FFXZA. I have been having intermittent issues where the tv will just shut off and go into stand by mode. It then will not turn back on. It will attempt to, but I will not hear the click and the power light will just flash before going back into stand by mode. There is no image at all. I've taken the tv apart several times to check for bulging capacitors, but they all look good. After putting the cover back on, it will usually start working normally again. Sometimes when I unplug it and let it sit for an hour, it will also function normally again. A couple days ago, I got it working again by taking it down from the wall mount, standing it up on the floor along its bottom edge, removing the back cover, then it turned on normally. I put the cover back on, rehung it on the wall mount, then it wouldn't turn back on. I want to say it's the power supply causing the problem, but I'm not certain. Before I start throwing parts at it, I thought I would get your opinion.
    Top Expert:
  • Samsung Master
  • 85,020 Answers
It is a waste of time to even try to fix it as the parts will more than likely be obsolete.
Posted on May 19, 2017
SOURCE:
My dell inspiron 1525 keeps turning off and shutting down without me doing anything. why?
The computer has a cpu fan that can get dirty over time. It's job is to keep the cpu cool. When the cpu overheats, the computer senses it and shuts it down immediately, to prevent permanent damage to the cpu. You can clean it by blowing compressed air into it, and should do that every few months, as routine maintenance. This is the most common thing that shuts a laptop down, other problems involve repair, so try this first. I bough a $7 three inch fan at Walmart to help cool the laptop, and when I run it, I never have it shut down on me, but once in awhile it will without the fan, especially when I play dvds or videos, which really work th' heck out of the cpu. There are also commercial laptop cooling devices, but my little fan works just fine. Hope this helps.
Mar 29, 2010 | Dell Inspiron 1525 Notebook
The tv shuts off by itself. I will turn it on..and after awhile, it just turns off by itself, and then after about a minute I can turn it on again and watch tv for awhile, and then it will do it again.
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The faulty component(s) are heating up, tripping the fault control, and shutting down, it cools down again,and will restart, then the process repeats, it will eventually fail fully.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Mar 04, 2010 | Televison & Video
I replaced the lamp bulbs and the TV worked fine for awhile but shut off after about three days of use. I unplugged it and waited awhile to plug it back in the timer light blinked for awhile and then went...
While it is suspicious happening so soon after lamp replacement, your main power supply may have failed. In earlier sets, these were problems that eventually happened.
Feb 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Hello, My LRDC22731ST ref. freezer leaks
Good day,
The drain hole is there, but you must remove the rear panel in the freezer. You can try extremely hot water repeatily to try to get it to flush.
If no luck, try a hot water and a weak solution of bleach. Repeat, and be patient. Takes awhile sometimes.
If neither works, you'll have to remove the back bottom cover and blow out the drain hose.
The machine should be turned off when performing these proccedures.
Thank you for using FixYa
Jan 24, 2010 | Refrigerators
Samsung HLP5063W looses picture, turns off wont turn on and more
Ensure that the TV is off. It may be advisable to unplug the TV as well.
2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
Make sure your TV is off and cool when performing this procedure.
Jan 23, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
My lc320 and will not come back on -
My screen turned black in the middle them spreaded out to cover the whole screen also i have no sound. It reacted like that twice now its completely gone after 6mths.
Jul 04, 2009 | Sylvania LC320SS9 32 in. LCD TV
Volume will just blast real loud
If you have a remote control , unplug the lead from the volume control (at the back of the machine) and instead of it plugging into the Inrfa Red control unit in the base of the cabinet, plug it straight into the amp volume input.
There has been problems with the remote that does what you are suggesting so this will prove the point.
Jan 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have the williams wall mount & it shuts down after awhile..
Probably needs to have the burners blown out. The yellow is a sure sign of rust and stuff inside the burners disrupting the formula of air to gas ratio. Just needs a good blowing out.more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 10, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Insignia ns 2v17b froze and won t turn back on? PLEASE HELP!!!
the solution to this is to unplug the batery from the player itself. you have to open it by taking a jewellers screwdirver, pry out the rubber cover from the back. it is the only one that is on the battery cover. after doing so it will reveal a philipps head screwdriver. simply unscrew it and unplug. be very careful and pry the sides of the battery cover slowly sliding and prying downwards.. unplug and plug back in again.
the solution to the other problem here is that you guys and gals are unplugging the player prematurely meaning. You just simply unplug it from the your computer w/o safely removing your hardware. by doing this straight unplugging from the pc, yu are corrupting the hard drive on your usb and eventually end up breaking it.
Apr 27, 2008 | Insignia NS-DV2G MP3 Player
Televison & Video Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
