Question about Optics
I own a 50 cal black powder CVA rifle with serial number 0055658 Made in USA and I need Pins that hold Rifle to Stock. Can you help /
SOURCE: winchester model 100 semi-auto 308 cal. how to disassemble?
IMPORTANT Recall info:
WINCHESTER MODEL 100 FIRING PIN RECALL - A notice dated 7-1990 relates the following
“PRODUCT SAFETY WARNING AND REPLACEMENT NOTICE. Attention owners of Winchester model 100
rifles and carbines please read this notice. In July of 1990 the following product safety
warning was issued by Winchester. It has come to our attention that the firing pin in the
Winchester Model 100 Rifle or Carbine may break due to use and metal fatigue and become
lodged in the breech bolt face. If this occurs, the firearm may fire before the action is
locked causing severe damage to the firearm and possibly injury or death to the shooter
and bystander.
WARNING DO NOT SHOOT YOUR WINCHESTER MODEL 100 RIFLE OR CARBINE. Repair and replacement.
A new firing pin has been designed to replace the firing pin originally made for the
Winchester Model 100 Rifle and Carbine. The new firing pins will be available in April
1991. If you own a Winchester Model 100 Rifle or Carbine, please send your firearm to one
of the authorized Winchester Model 100 Firing Pin Replacement Centers indicated below.
Your Winchester Model 100 firearm will be inspected, the firing pin replaced and tested
and the firearm returned to you. The inspection, replacement/testing and return postage
will be accomplished at no cost to you. If other repair or maintenance work is authorized
by you to be performed on the firearm when the firing pin is replaced, such work shall be
at your cost.”
W. R. Long Gunsmiths
2007 Brook Road North
Cobourg, Ontario K9A4W4
Canada Frank LeFever & Sons
RD 2 Box 31
Lee Center, NY 13363
USA Bolsa Gunsmithing
7404 Bolsa Avenue
Westminister, CA 92683
USA Nu Line Guns
1053 Caulks Hill Road
Harvester, MO 63303
USA
If you have any questions concerning this notice, call Winchester Product Service
1-800-852-5734 or write to Winchester Firing Pin replacement Notice, PO Box 10 Cottage
Hills Illinois 62018 Attention Product Service Dept.
The following is Wisner's rendition & info on the subject.
The difference in the old firing pin and the new one is as follows. The old replaced
style, was totally lathe tuned (round). While the new recall style is similar in lathe
turning on the front and back, but in the front midsection it has two flats milled, one
on each side. This makes the center section stronger. Also replaced is the bolt sleeve
lock pin (firing pin guide) which was made to accommodate this different shaped firing
pin
Part number for the new parts are, firing pin =1391ND, bolt sleeve locking pin =1491ND
The word was at the time this recall was in process was that if the firing pin would
break at the mid section and still remain in the gun as two pieces, the possibility of a
premature discharge before the bolt was locked was possible. This apparently was caused
by the firing pin tip (now not having a retracting spring) to be stuck forward, and
thereby slam-firing upon chambering.
The responsibility for the recall apparently was on Olin, as they were the parent company
at time of manufacture. Olin set up regional recall centers at three established US
gunshops. There was a manufacturing delay in the replacement firing pins, and a backlog
occurred, also some collectors did not like the idea of shipping their guns long
distances. Olin then also authorized other gunshops to make the required alterations.
Upon completion of the recall, the shops were to test fire the firearm and to stamp an
assigned letter on the inside top of the receiver as seen thru the magazine well with the
bolt retracted. The letter “B” represented Bolsa Gunsmithing, “L” was Lefever, and “N”
was for Nu-line Guns. The letter “X” apparently was for all the other independent shops.
However this identification information did not get communicated to some of the smaller
shops at the start of the project. The only way to tell if the gun as been modified, if
the ”letter” is not present, is to take the barrel & action out of the stock, remove the
trigger guard assembly and the try to rotate the firing pin by twisting it. If it does
NOT rotate, then the firing pin recall HAS been performed.
For link back to the parts & price list that we make & have for sale CLICK HERE
Copyright © 2004-2007 Wisner's Inc. All Rights Reserved
Back to Additional information To Winchester model 88 & 100 parts
Originated 01-13-2001 Last Modified 03-19-2007
LeeRoy Wisner
Posted on May 20, 2009
  • 2418 Answers
SOURCE: I am using Hodgdon 4895 smokeless powder and a 200
Oh me, that was fun I have not got out my books for so long.  Ok this is from Hornady Handbook Starting load for the 200 gr RN Bullet using H4895 is 34.3 gr using a Remington case with a Federal 210 Primer Max C.O.L. (Cart.over all length) is 1.920. Max load for this is 39.0 gr. Work up, look for case bulging & primer flowing. Be carefull.
Posted on Sep 24, 2009
cuvilldj
  • 14 Answers
SOURCE: where is the serial number located on a remington
693f0fe.jpg Introduction Year: 1936 Year Discontinued: 1955 Total Production: Approximately: 12,200 Designer/Inventor: C.C. Loomis, A.L. Lowe, K.J. Lowe Action Type: Bolt Action – Clip Magazine Caliber/Gauge: .22 Long Rifle Serial Number Blocks: Starting: 00001
Ending: 12300 Grades Offered: Model 37 Rangemaster
37 Target
37AR
37AF
37AX
37AM
37AV
37AS Variations: None
Posted on Dec 11, 2009
  • 18 Answers
SOURCE: Where can i find a replacement stock for a
Numrich arms might be able to help you 866-686-7424 in Or try egun parts on the web. Good luck.
Posted on Mar 11, 2010
  • 4 Answers
SOURCE: Just wondering what its worth....Very
Is it in good or bad condition
Posted on Jan 06, 2013
Serial # range for marlin model 60 with 18 shot tube and last shot bolt hold open
On Marlin-branded Model 60 rifles, the first two digits of the serial number indicate the year of manufacture. For example, if the serial number starts with 18... The 18 is significant, for subtracting it from 2000 gives the date of manufacture for the rifle, 1982. Likewise, a serial number starting with 17 would be a rifle manufactured in 1983.
This method has not been uniformly followed. It is valid only from 1971 through 1999. Prior to 1971, the first two digits indicated the year of manufacture. For example, a rifle with a serial number starting with 70... would have been made in 1970. Starting in 2000, this same old method has returned; the first two digits once more indicate the year of manufacture directly, with no subtraction required.
Sep 17, 2016 | Marlin Model 60 .22 Cal Rifle
I was told there was no such thing as Benjamin Franklin mod 312 Ser h322837 but is in enshrined on the barrel, I need to know
Definitely exists and looks collectible.
  • Benjamin Franklin 312 .22 ' Gun Values Board www.gunvaluesboard.com/benjamin-franklin-312-.22-2923214.html My father has a Benjamin Franklin , model 312 .22 cal. Lever pump rifle , ... A Benjamin 22cal air rifle with a ser ... .22 cal Mod. 312, ...
  • i have a benjamin franklin 312 air rifle with no serial ... https://answers.yahoo.com/question/index?qid=20110411133733AAHQmgM
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2011-04-11 · I have a benjamin franklin 312 air rifle with no serial numbers on ... What you have is a Benjamin model 312, ... I have a benjamin franklin 312 air ...
  • Advice on what to do with Benjamin 312? - Airguns & Guns ... www.gatewaytoairguns.org/GTA/index.php?topic=25607.0 Advice on what to do with Benjamin 312?, ... Benjamin Pump mod. 397 ... SE CT; Beeman C1 .177 Daisy 230 (Milbro)
  • Related searches for Benjamin Franklin mod 312 Ser h322837
  • I Have A Benjamin Franklin Model #312 - Lever Pump Air ... www.gunvaluesboard.com/i-have-a-benjamin-franklin-model-312...rifle... I have a Benjamin Franklin Model #312 - lever pump air rifle in .22 cal. The stock is broken & I would like to get it fixed. ... A Benjamin 22cal air rifle with a ser ...
  • Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle ... www.ebay.com/sch/sis.html?_nkw=Benjamin+Franklin+Brass+Mod+312+22... Find best value and selection for your Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle Gun For Parts search on ... Benjamin Franklin Air Rifle for parts . $ ...
  • Item:8679966 Benjamin Franklin 312 AIR RIFLE PARTS .22 For ... classic.gunauction.com/search/displayitem.cfm?itemnum=8679966 Seller's Description: Benjamin Franklin 312 AIR RIFLE PARTS .22 Nice old Benjamin 312 barrel, receiver and stock Pumps air okay but there is no way to release it as ...
  • benjamin franklin 312 - Airguns & Guns Forum www.gatewaytoairguns.org/GTA/index.php?topic=37115.0 benjamin franklin 312, Air guns, Airgun Forum ... 2 RWS mod. 48s, 177, & 22 2 Benjamin Marauders 22, & 25 Benjamin Trail NPXL1100 Benjamin Pump mod. 397, ...
  • Benjamin 312 strip, tear down & dis-assembly - YouTube www.youtube.com/watch?v=W1_DGNaaAs0
    • BY NORTHWESTAIRGUN
    • 17 MIN
    • 45K VIEWS
    2014-02-06 · Video embedded · Video of the dis-assembly of the Benjamin, or Benjamin Franklin, model 312. This is similar to the model 310, 317, 342, 347, and ...
  • Ben franklin air rifle mod 312 parts diagram - fnsxowf.gq fnsxowf.gq/zeuimpooku I have come across a Benjamin Franklin Mod.340 Cal.Buy Benjamin & Sheridan ... Benjamin Franklin 312 Pump air rifle.New airguns and vintage are available in our ...
  • Need A Repair Kit For A Benjamin Air Rifle Model 312 ' Gun ... www.gunvaluesboard.com/need-a-repair-kit-for-a-benjamin-air-rifle... need a repair kit for a benjamin air rifle model 312 ... I bought an old Benjamin air rifle model # 312. ... I have a Benjamin Franklin Model #312 ...
  • What is my Benjamin Franklin model 312 cal 22 h148881 man in USA
    May 20, 2016 | Optics
    I have a winchester ranger 270 cal. Rifle . Was wonde ring what model it is .... the serial number is G1871685
  • Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 ... 6.5×55mm, .264 Winchester Magnum, .270 Winchester, ... 70 Winchester rifles is the serial number ... the Winchester Model 70 rifle and Winchester Model ...
  • What is the value of Winchester ranger 270 caliber Serial? www.answers.com > ... > Firearms > Winchester Firearms Answer The Winchester 270 .22 was first introduced in 1963. It is not a collector item, or "rare". It is however a very good .22 rifle which should be enjoyed as ...
  • .270 Winchester - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/.270_Winchester Large rifle: Maximum pressure: 65,000 psi (450 MPa) Ballistic performance; Bullet weight/type Velocity Energy; ... The .270 Winchester (or 6.9x64mm) ...
  • winchester ranger .270 - Shooters Forum https://www.shootersforum.com/.../31131-winchester-ranger-270-a.html
    • 16 POSTS
    • FIRST POST: 2006-07-18
    2006-07-24 · Shooters Forum > Rifle and Rifle Cartridges > Rifles and Rifle Cartridges: winchester ranger .270 ... Winchester. Think push-feed M70 serial ... Ranger" mean? Caliber ...
  • What Is The Value Of A Winchester, Model 70, Cal. 270 ... www.gunvaluesboard.com/what-is-the-value-of-a-winchester-model-70... What is the value of a Winchester, Model 70, Cal. 270 ... of a Winchester, Model 70, Cal. 270 rifle. Serial number ... a Winchester model 70 270 cal the serial ...
  • 575 - Winchester Ranger .270 cal bolt-action rifle. Only ... www.proxibid.com > Firearms & Military Artifacts 575 - Winchester Ranger .270 cal bolt-action rifle. Only fired off one box of ammo.
  • Ranger T - Winchester LE winchesterle.com/Products/handgun-ammunition/ranger/t-series/Pages/... Ranger; T-Series; T-Series. When a ... Winchester T Series is ammunition that always performs at its best-even when things are at their worst. ... Rifle Ammunition ...
  • Winchester Ranger (M70?) .270 Win ' Gun Values Board www.gunvaluesboard.com/winchester-ranger-m70-.270-win-8295726.html I have a Winchester Ranger Serial # 5352836, 30-30 cal. Has a ... Tips for finding accurate ammunition for a .270 Win. chambered rifle. ... 1985 Winchester Ranger ...
  • Is a Winchester Ranger 270 cal a long action rifle? - Answers www.answers.com > Categories > Hobbies & Collectibles > Firearms Is a Winchester Ranger 270 cal a long ... What will excite ANSWERS.COM users for them to go ... The .270 Winchester is a great rifle for medium sized game such as ...
  • 270 Winchester Caliber Rifles for Sale - Online Gun Store ... www.ableammo.com > ... > Firearms > Rifles > Shop by Rifle Caliber We carry 270 WINCHESTER caliber rifles for sale in our online gun shop, including hunting rifles, tactical rifles, and more. We stock Browning BLR rifles, Remington ...
  • May 01, 2016 | Optics
    Single shot looks brass black powder only hopkins and allen arms cor N.J. U.S.A S.Marco cal.58 #2279. WHAT IS IT WORTH?
    Good afternoon Jay.
    I found a couple .58 Cal Lyman Muzzle loaders for sale here:
    Muzzleloading Rifles Modern Replica Percussion For Sale that were posted for $600. A H&A .22 rifle here
    FALLING BLOCK 22 RIFLE was listing for $250 Wish I could get closer than that, but listings on H&A tend more toward shotguns and pistols, and have prices anywhere from $30 'wall guns' to $500+
    Cheers
    D
    Dec 03, 2015 | Optics
    How to determine the model and serial number of a marlin 22 rifle?
    this is copied from a site, the web address is pasted below.
    The serial number depending on the model of rifle, will be located either on the upper or lower stock tang, or side of the receiver.
    http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
    also if you find serial # you may find more info here.
    http://oldguns.net/sn_php/marlinlookup.php
    From 1962 thru 1968 Marlins rimfire rifles (other than the 39 series lever actions) used a two letter date code that was stamped on the barrel. This date code is different than the one already listed, as Marlin rimfire rifles (other than the model 39 series) did not have a serial numbers until required to by Law after 1968. The first letter of the date code represented the month of manufacture while the second letter indicated the year. This date code was usually stamped on the left side of the barrel just in front of the receiver.
    Jan 19, 2015 | Marlin Model 60 .22 Cal Rifle
    Proper loads 4 an Olympia .50 cal. Muzzle loading rifle using pellets instead of powder.
    MAXIMUM LOAD WARNING 45 and 50 CALIBER RIFLE:
    45 Caliber Pellets come in one size: 50 grain
    50 Caliber Pellets come in two (2) sizes:
    50 grain volume equivalent which equals 50 grains of loose powder by volume.
    30 grain volume equivalent which equals 30 grains of loose powder by volume.
    The maximum load per shot should never exceed total Pellets containing more than 100 grains volume equivalent. That means, no more than:
    45 Caliber 1) Two (2) 50 grain Pellets
    2) Three (3) 44/45 caliber 30 grain
    50 Caliber 1) Three (3) 30 grain Pellets, or
    2) Two (2) 50 grain Pellets, or
    3) One (1) 50 grain Pellet and one (1) 30 grain Pellet
    54 CALIBER RIFLE:
    54 Caliber Pyrodex Pellets come in one size only:
    60 grain volume equivalent which equals 60 grains of loose powder by volume.
    The maximum load per shot should never exceed 120 grains (2) Pellets.
    Oct 12, 2014 | Optics
    How do I remove the breech block on a .50 cal muzzleloader so I can clear a stuck round?
    "a round stuck in the barrel"
    From that statement I assume you mean you had a bad load, and when fired the ball when only part way down the barrel and got stuck, correct?
    If so, rather than unscrewing the "breech plug", you might want to try the less invasive old time method.
    You might try a ".50 cal black powder bullet puller":
    http://media.midwayusa.com/productimages/880x660/Primary/673/673644.jpg
    Attach it to the end of a cleaning rod, and screw the end into the ball.
    The brass ring is non-marring in the steel bore.
    Once screwed in good, pull it out!
    Or, you might try a "CO2 bullet discharger":
    http://www.buffaloarms.com/ItemMedia/10024/10024_44151.jpg
    Remove the nipple (if a percussion action), and shoot the blast of air through it, pushing out the bullet (have it pointed in a safe direction!)
    Sep 09, 2014 | Optics
    Rifle manual for 50 cal.black powder rifle tradition mod.timber ridge 209
    A load for a 50 caliber rifle calls for 90 grains of FFG black powder or 90 grains of Pyrodex RS (maximum, start with a lighter load, and work your way to a good, accurate loading).
    I'm not understanding the rest of your question.
    Feb 23, 2014 | Optics
    Optics Logo
    22 people viewed this question
    Top Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    james laughton
    james laughton
    Are you an Optic Expert? Answer questions, earn points and help others
