Question about The Watches
What is the resale valve of this watch ? It also has the date.
How much is my 185776 bulova 18k worth?
Looks like a nice watch. But there are several things that affect the value. First it is a women's and they dont hold the value as well as a mans watch will. second it is a bulova and the resale on those over the years have not kept up the pace because there are so many out there and Bulova has always been a ok watch it has many contenders that are much better. So the worth lies in the weight of the gold. !8k is good but make sure it is real, from the photos the bracelet do not look like it is solid gold looks like it is 18k plated.
May 31, 2017 | Bulova Watches
How to set new date of month on watch
How to change date on a watch?
Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. * If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock. 5. Adjust the time by turning the crown in the desired direction.
Instructions for Analogue Quartz and Mechanical Watches - Seiko
https://www.seikowatches.com/support/ib/pdf/Analogue_E.pdf Search for: How to change date on a watch?
How to set new date of month on watch Google Search
Dec 21, 2016 | Watches
My watch is changing date at 2 am instead of at midnight, i have tried rechanging it manually, but still each day at 2 am it changes the day again. Why it not change at 12am O'clock what I can do pls
Thread: Tag Heuer Carrera changes its date at 3:00 am instead of ...
forums.watchuseek.com > Forum > Watch Brands > TAG Heuer
Jan 1, 2012 - 6 posts - ‎3 authors
The watch used change the date, as it should, at midnight but I just noticed last night that it now waits until 3:00 am... Does anyone have any ideas. ... Join Date: Jan 2012; Posts: 2 ... Changing the date on an automatic watch - Watchuseek ...
Mar 2, 2015
Damage of changing date at midnight on automatics ...
Oct 18, 2013
Setting the date destroys the watch? - Watchuseek, The ...
Sep 8, 2010
Thread: Does setting date between 9pm and 3am damage ...
Jun 6, 2010
More results from forums.watchuseek.com
How do analog watches know to change the date at ... - Quora
https://www.quora.com/How-do-analog-watches-know-to-change-the... QuoraThere is a gear within an analog watch that is used to change the date at the appropriate time. The gear ... Watches: What is a fair price for a authentic 1970's vintage "McQueen" Rolex Explorer II? Why does the day start at midnight?
Jan 21, 2016 | Watches
Find out if a watch i have is worth money
Check to see if your watch or one closely resembling it, is for sale on Ebay. This generally gives an idea of value, at least in terms of resale and value. Watches, other than Rolex and very high end types, don't have very good resale value. Of course, all of the value may be in the diamonds or 14K cases, no matter who is the maker.
Dec 13, 2014 | Waltham Watches
Just got a new Seiko watch but the date won't change automatically
Main cause would be that the date gear teeth have been stripped. This is done by setting the date whilst the hands are trying to change the date themselves (between 10pm and 2am). Always adjust the date with the hands around 6.0clock. You will need to return your watch to where you bought it for repair I'm afraid.
Jan 18, 2013 | Seiko watch - SXDA42 Watches SXDA42 Ladies
Hi, My watch is changing date at 12 noon instead
Your watch is 12 hours out of step. (The date changes every second revolution of the hour hand.)
Wind your watch forward 12 hours, (you may have to reset the date) and it will then change around midnight.
Jun 07, 2011 | Hamilton X-Wind H77646733 Wrist Watch
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
May 28, 2011 | Timex Expedition® Metal Field 47042...
Polar A5 wrist watch
Have you thought of taking it into a watch specialist.
I would advise you not to accept adresses on this site for your watch to get repaired .
Does it run on a lithium battery ?
Aug 04, 2008 | Polar A5 Wrist Watch
Watches Logo
13 people viewed this question
Top The Watches Experts
D. E. Hev
vince
gbob59
Are you a The Watch Expert? Answer questions, earn points and help others
