Phillips 37pfl5322d/37 powers up ok, but when I push the MENU button, it shuts down
Slinteriors
  • 8617 Answers
SOURCE: No sound from Phillips 37 LCD
The audio output IC is probably faulty this cost only a few dollars if you replace it your self.Let me know if you need further assistance or more information.
Posted on Mar 30, 2008
budmrtn
  • 11361 Answers
SOURCE: My 37PFL5322D 37" LCD has no picture and no
Pictures in my albums and my guides may help you out also.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 21, 2011
  • 484 Answers
SOURCE: Need to reset phillips gogear
Your player might hang up. Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software and repair device with it.
Contents will be removed by using the repair function.
How to do it is described on the manufacturer's web site here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&mid=Link_FAQs&view=aa12_view_partial.html&session=20110504030502_93.189.114.198&list=aa12_list_partial.html&slg=AEN&ctn=SA2627/37&dct=FAQ&refnr=0073454&faqview=1
Thanks.
gylacz
Posted on May 04, 2011
Ecollier2012
  • 3459 Answers
SOURCE: Phillips model 37PFL5322D/37
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on May 09, 2011
  • 16 Answers
SOURCE: Model 37PFL5322D/37 phillips tv has a fast clicking sound in the power supply, what will cause this.
possible the main relay in the power supply board may need soldring or you could have a stickey relay
Posted on Jul 13, 2012
Model 37PFL5322D/37 phillips tv has a chirping sound, no picture
Your TV is exhibiting a symptom of power supply trouble but repair is not a casual task.
Dec 20, 2013 | Philips 37PFL5332D 37 in. LCD Television
Tip
Customize the Shut down button windows 7
Customize the Shut down button The default action of the Start Menu's Shut down button is to turn off your PC. If you want to use the button for another action, such as restarting your PC, you click the arrow to the right of the Shut down button and select an action from the drop-down menu.
What if you rarely shut your PC down completely but frequently restart it? You can change the Shut down button's default action to be Restart -- or Switch user, Log off, Lock, Sleep or Hibernate.
To change your default, right-click the Start button and select Properties. On the Start Menu tab, click the "Power button action" drop-down menu and select which action you want to be the default. Then click OK, and OK again.
on Jan 12, 2010 | Computers & Internet
Philips 37PFL5322D
Your remote control need cleaning. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now.
Pull up older posts there. have all details about how to clean a remote control.
Sep 12, 2012 | Philips new universal remote control...
Jul 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
Phillips model 37PFL5322D/37 was watching unit and just shut off--no click or pop, just shut off....unplugged power for 1 minute and tried to power up--nothing--will not power on...checked power...
Apr 16, 2011 | Philips 37PFL5332D 37 in. LCD Television
If the set is responding to the remote or set-top buttons, this means only that the always-on low voltage supply for the remote section is working and that the main power supply has probably died. You might try pulling the AC plug overnight to see if there is simply a 'lockup' of an IC causing the non-response. Our modern sets are very complex and it isn't uncommon for them to have a glitch while operating.
Mar 08, 2011 | Philips 37PFL5332D 37 in. LCD Television
Mar 30, 2008 | Televison & Video
Phillips 32 in. tv
bad front panel need to get new one ok sumthing loose or went out
Feb 04, 2008 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
