Question about Briggs Measuring Tools & Sensors
How to get a briggs and stratton power wash engine to shut off
    Top Expert:
  • Briggs Master
  • 26,670 Answers
If petrol, there should be either a cut out switch or a spring over the spark plug to stop the spark Or turn the fuel off.
Posted on May 19, 2017
I have a briggs and stratton 030547 3500 Watt generator and the engine has locked up, what can i do to fix this issue??
Remove the spark plug and crank the engine . Usually it has been flooded or shut while in full choke mode. This causes the condition you describe. If that fails you have internal issues and low oil was the culprit.
Jun 05, 2014 | Briggs & Stratton Electrical Supplies
I need a oil seal for a 15.5 briggs and stratton engine
try locating a bearing warehouse, they have listings for all size seals.
Apr 07, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have a Briggs and Stratton Elite series5500 watt portable generator. I cannot get it started. It has gas and oil but will not start. What could be the problem
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Turn off gas tap if present. Remove the float bowl while holding a container under it to collect any gas. Turn on tap and check the fuel flows freely.
Check the air filter is clean. If it has foam elements these can be washed with warm water and detergent, rinsed and then oiled with a teaspoon of oil evenly distributed through the foam.
May 01, 2011 | Briggs & Stratton Briggs and Stratton...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Measuring Tools & Sensors Logo
Top Briggs Measuring Tools & Sensors Experts
BrikimG
Level 1 Expert
Lawrence Oravetz
Are you a Briggs Measuring Tool and Sensor Expert? Answer questions, earn points and help others
