Question about Panasonic Lands Phones
HI I HAVE A PANASONIC KX-T7533 WHEN I PICK UP THE HANDSET TO MAKE A CALL THE SCREEN WRITES "CO NOT ASSIGNED" WHAT DO I HAVE TO DO ??
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
cnavarro
  • 2460 Answers
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
Posted on Jan 21, 2009
SOURCE: Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
Posted on Jul 28, 2009
  • 224 Answers
SOURCE: hi ihave a panasonic kx-mb781 and it say on
Fuser unit cannot heat up. Replace fuser unit.
Refer to CALL SERVICE 3 (P.120).
Posted on Mar 31, 2010
HOW TO SET THE TIME IN PANASONIC PHONE KX-T7533
Try Googling (Panasonic)(KX-T7533)(manual) without parens for instructions.
Sep 12, 2017 | Panasonic Lands Phones
Changed Assigned CO numbers
Try Googling (Panasonic)(KX-NT343)(manual) without parens or contact Panasonic directly to request a copy.
Oct 26, 2017 | Panasonic KX-NT343 IP Phone - KX-NT343
Don't see my phone line once someon else picks up a lilne on My Panasonic KX T7433
Start by pressing PROGRAM 99 on the phone and press the line buttons one a t a time. It will tell you what CO(central office) line is assigned to the button.
They should be in sequence 1,2,3,4 etc. If they don't, dial 0 + 0x STORE to program it and make it work.
Carl
Aug 22, 2012 | Panasonic KX-T7433B Corded Phone
I have a PANASONIC KX-DT333 with several handsets. On all handsets we cannot dial out . The message LINE NOT ASSIGNED comes up on all handsets.Also we have had no incoming calls. Callers are all getting a...
I don't know about a handset, since mine doesn't have a dial, but the phone underneath the handset has to have a button programmed with the lines you use in order to work. By default, the system has some number of Single CO buttons assigned in numerical order from the bottom to the top and left to right. You can test that by pressing PROGRAM, press the line buttons in sequence, and reading the display. They will say CO 001, 002, 003 etc. If they don't, you can always dial 0 001 store, 0 002 store etc and get the line appearance back.
This solution works in a small system and is very basic. It doesn't take a T1/E1/PRI or group CO buttons. into consideration. Such a solution is beyond the scope of a free forum.
Carl
Mar 13, 2011 | Panasonic KX-T7633 Corded Phone
Panasonic kxt7630 button assignment
I've never heard of the ability to reassign an intercom button as it's a fixed feature, but maybe so. Start by assigning the lower left phone button back to CO1 and let's see what happens. WIthout picking up the handset, press PROG the button and dial 0+01 STORE or ENTER.
Pick up the handset and drop it back in the cradle to exit programming.
Did that work? Making button 1 into CO1 will drop the programming from the intercom button and it should default back to intercom.
Carl
Apr 15, 2010 | Panasonic KX-T7630 Corded Phone
Panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
I HAVE STILL GOT ALL THE SPEED DIAL NUMBERS IN MY TELEPHONE BUT SEEM TO HAVE LOST THE OUTSIDE LINE TO CALL ANYBODY, ALL I GET IS co NOT ASSIGNED, CAN ANYBODY HELP ME THROUGH IT?
If your 773x phone is connected to most Panasonic systems, you can press PROGRAM and the place where lines are supposed to be assigned and it will tell you what's under the button with names like CO1, CO2, CO3 etc.
If it says something else, you can make it become outside line access buttons by the command 0+a number 1,2,3 and STORE.
You can do all 3 buttons at once, just keep pressing them and dialing the sequence with a STORE. After you've finished, just pick up the handset and drop it back down to end programming.
Carl
Apr 22, 2009 | Panasonic KX-T7730 Corded Phone
I have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
Feb 04, 2009 | Panasonic KX-TG1033S Cordless Phone
KX-T7731 messed up the co button
Remember that PROG 13 you pressed? First, press PROG and touch CO-1's button and make sure it still say CO-1. If not, dial 01 STORE and it will become CO-1 again.
Now, pick up the handset and hang it up so you clear the phone and press PROG 13 1 STORE PROG
Easy when you have the manual :-)
Carl
Oct 08, 2008 | Panasonic KX-T7731 Corded Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
