Question about Samsung Cell Phones
My Samsung J3 screen goes blank after about 10 seconds after I turn it on. I constantly have to hit the lower middle button and it brings me back to the home screen. Can I change the timing? Thank you
    Master:
  • Samsung Master
  • 515 Answers
Yes you can change the time
Posted on May 20, 2017
I have a black screen after charging a samsung j3 2016 phone. tried several suggestions from utube but nothing helped. its in perfect shape only 6 months old
if you press the button on the rh side of the screen
That is the on/off button and may require a bit of fiddling to get it to switch on as it only moves a bit and is smaller that most fingers
next press the bottom at the bottom of the screen
the j3 units takes a few seconds to respond to on/ off so press once then wait for a reaction
if the battery is charging , regardless of on/off the battery sign will appear with the % of charge when the charger is plugged in so if that is not appearing , it could be a faulty charger
you can download a full pdf version if you google -- user manual for samsung J3 mobile phone --
Oct 31, 2017 | Samsung Cell Phones
How to clear and load cmos default bios parameter for a Aspire 5630 modle no. BL50?
Two methods;
A)
1) Remove ALL power to the laptop, except the CMOS battery.
Remove the AC adapter (Charger) and Battery.
2) Press the Power On button in, and hold it in for a full count of FIVE seconds.
Let go of the Power On button.
Do this procedure TWO more times. (Important)
This procedure clears CMOS Error Codes, and resets BIOS Setup back to the factory default settings.
Reinstall power. Install the Battery FIRST, then the AC adapter.
B)
Go into BIOS Setup.
As soon as you press the Power On button, start tapping in 2 second intervals, on three keys at the SAME TIME.
Press all 3 keys at the same time.
CTRL, ALT, and ESC.
No?
Hold the Power On button down for 10 seconds to turn the laptop off.
Wait 30 seconds, turn the laptop back on.
As soon as you press the Power On button start tapping on the F2 key.
(Tap in 2 second intervals)
When in BIOS Setup look at the main page, and towards the bottom.
Here you will see an F key listed that when pressed, will revert BIOS Setup back to the factory default settings. (Generally F6)
C) Remove all power from the laptop.
Lay a towel on a table, and lay the laptop upside down on the towel.
Open the Memory Compartment Panel, and remove all ram memory modules. ('Stick')
Located towards the middle of the ram memory compartment is the J3 jumper.
There is a J3 with a square line going around it.
This jumper is used to clear any settings made, and will go straight back to all factory default settings.
In otherwords if someone set a BIOS password, the J3 jumper will remove it.
Factory setting for BIOS password is no password.
Regards,
joecoolvette
Oct 09, 2011 | Acer Aspire 5630 Notebook
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Apr 15, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Screen goes blank every 30 second, have to hit the
go to control panel > power options. Turn off hibernate and sleep mode, change all settings to never sleep and change the setting for "when closing the lid" to "do nothing" sleep mode, hibernation can destroy the registry on these laptops, you are better off turning that garbage off and just letting it run.
Nov 15, 2009 | Computers & Internet
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Sep 14, 2009 | Samsung DLP HL-P5663W 56" TV
Screen goes blank
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Oct 14, 2007 | Timex Ironman Triathlon 51931 wristwatch
Cell Phones Logo
51 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
