Question about Whirlpool Microwave Ovens
Whirlpool microwave model number WMH1164XVS-0 turntable keeps turning when door is opened and unit will not start up, displays "close door" while door is closed.
    Top Expert:
  • Whirlpool Master
  • 23,168 Answers
Check the door switches.
Posted on May 19, 2017
Testimonial: "I pulled out all 3 of them, ohm'd them out and they all are good, is there anything else that could cause this issue?"
  • JonSnell Electronic
    JonSnell Electronic May 20, 2017
    With the switches disconnected and made safe, reconnect two are change over type. Also if one door latch is broken or malfunctioning, this may cause similar issues. Check the service manual.
Samsung microwave turns on when open door
The switch assembly is somehow staying "closed" satisfying the interlock and enabling it to run.
Disassemble the unit, beware specially of the high voltage capacitor, if you aren't comfortable or competent, buy a new microwave. If you are mechanically inclined, disassemble the unit until the switch assembly is accessible; it will have the door latch attached to it.
The switch is either broken or something? exogenous is keeping it closed. It may have come loose due to the door slamming?.
It's a simple fix. I am certainl you will be successful.
May 04, 2017 | Samsung Microwave Ovens
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
Whirlpool Microwave (model WMH1164XVS-1 ) does not turn on
This could be a lot of things. IT might be a capacitor or diode. MY money is on the capacitor. Since it works for a minute before it quits.
May 06, 2013 | Microwave Ovens
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
I have a model number EM925RSL-B and the timer counts down but it does not heat up or turntable does not move?
I just bought an RV with the exact same microwave and the exact same problem. The problem with mine is the switch that detects that the door is closed is not getting activated. The reason for this is is the finger at the top of the door is damaged as well as the plastic piece that the finger grabs onto when the door is closed. This causes the finger not to come into contact with the switch. To test this you can turn your microwave on and start it. open the door and using a small screwdriver, depress the micro switch you can see upper right side of the door opening. then press start again. your turntable will start turning and the microwave will make a louder noise as a fan will turn on. CAUTION! Release the button as soon as you see the turntable rotation as you will be receiving microwave energy due to the door being opened.
Jul 02, 2011 | Microwave Ovens
Whirlpool MT$155SPS-1 microwave
Cajun1112, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Cajun1112), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool MH6150XLS Microwave Oven
Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Nov 07, 2008 | Jenn-Air JMC9158AA Convection Microwave...
I have a Whirlpool AMW545 built in microwave oven. The turntable continuosly runs with the door shut when the microwave is not in use. The turntable will stop rotating if the door is opened.
the controller for the turntable is shorted out or welded its contact if its a relay. the door has safety switches that turns off the electrical connection to the turntable and magnetron once you open the door. you can trace the switch that runs the turntable. start from the power supply, goes to the door switch then to the controller before it goes to the turntable motor. i'm sure it has an electrical diagram at the inner wall of the cover.
i hope i was able to help.
Jun 27, 2008 | Whirlpool Microwave Ovens
Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 10, 2007 | GE JVM1350BW/WW/AW/SY Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
